Coil Spring clamps
Old Sep 18, 2012 | 11:01 PM
arellanogiovan's Avatar
Coil Spring clamps
Can i put coil spring clamps to my lowering springs lower it little more?
Old Sep 18, 2012 | 11:08 PM
MNfit's Avatar
NO NO NO NO NO. you can do what ever you want.... but NO NO NO NO NO
Old Sep 18, 2012 | 11:39 PM
solbrothers's Avatar
cut them. what's the worst thing that could happen? you crash your car into a yak?
Old Sep 20, 2012 | 10:38 AM
mahout's Avatar
You have to be very careful about using spring clamps; the problem is shortening the 'free height' so that the coil is loose on the seat at maximum reboud which could result in the spring popping out and you risk at least partial suspension collapse and towing home.
Proper spring clamps don't actually clamp one coil to the next but change the between coil separation to something less than before. The coils are actually clamped with a spacer between the coils to fix the separation. Properly done, the spacer differs one side to the other and some means is present to fix the clamp so it doesn't walk around the coil as it flexes.
That of course severely reduces the ride as its like using shorter but stiffer springs.
Now do you see why its not useful to use spring clamps? Only changing springs or coil overs will do what you're looking for.
cheers.
ps whats a little more? could you get what you want by grinding off a quarter inch on the seats of your springs? not the length.
Old Sep 20, 2012 | 10:41 AM
avocado123's Avatar
FALCON PUNCH!!
Old Sep 26, 2012 | 10:10 PM
Thank y'all!
doctor J
May 8, 2015 12:06 AM
jazzivtec
26
Dec 18, 2014 05:01 PM
Kurse
Sep 4, 2009 12:18 AM
F-IT!!!
Nov 1, 2007 12:15 PM
