[Question] Need help identifying part
Old Sep 29, 2012 | 02:55 AM
aneesheewah's Avatar
Question [Question] Need help identifying part
this part of my right rear window is hanging on it's last hope. i've actually taped it on because i have no idea how to go about replacing it. and i wanted to know if it's something i can fix on my own before i have a professional look at it. the part looks like a simple piece of plastic that hangs on by hooks, and one of those hooks seems to have broken off.
any help would be greatly appreciated. thanks!
Old Sep 29, 2012 | 03:22 AM
Subie's Avatar
Post a closer shot. Can't tell from that distance.
Old Sep 29, 2012 | 04:37 AM
Black3sr's Avatar
It is called DOOR REAR SASH TRIM
Order a new piece. There may be one screw holding it on inside ( I am quoting from a GE manual not a GD). The piece should slide up an off some hooks after the screw is removed. On the new piece you should see what needs to be done to install. Just slide it down on the hooks and put screw in.
Old Sep 29, 2012 | 10:51 AM
x4x5x1x's Avatar
Right out of the Honda catalog
GARNISH, R. RR. DOOR PILLAR 72721-SAA-003 $30.83
GARNISH, L. RR. DOOR PILLAR 72761-SAA-003 $30.83
vinnimac
Aug 29, 2018 04:11 PM
AuctionHugh
Apr 9, 2017 04:26 PM
GrayGhost
Oct 28, 2015 10:53 AM
Vipersnake
Dec 4, 2013 12:39 PM
k_pt
May 22, 2007 10:11 AM
