Rough idle during warmup
Old Nov 24, 2012 | 10:15 AM
JustinM's Avatar
Hi guys. Sorry if this has been asked before. There were some similar problems I found in searches but nothing that seemed to fit exactly.
My ~71k mile '08 Fit recently started, on occasion, having some rough idling when the engine is cold. I suspect the problem is with a sensor, though, because it only does this when the blue "cold" warning light doesn't come on. This means to me that the computer doesn't know then that the engine is cold and tries to have it run at "normal" settings rather than warmup settings.
Is my reasoning correct here? What should my next step be either to confirm the problem or fix it?
EDIT: I forgot to add that there is no CEL here.
Old Nov 26, 2012 | 10:07 PM
CTCT's Avatar
According to the dealer, to whom I took my car to for a similar problem, they can hook up your car to their diagnostic test set which is more comprehensive than an OBDII scanner. It can test the health of all sensors, apparently. It might cost you $100 at most.
Oh, and be prepared for the standard "you need a valve adjustment" response to which they'll ask $400 for. I'd rule out valves by having the adjustment performed, but not necessarily by the dealer. It's a relatively easy job.
gracefulfailure
Aug 19, 2016 08:04 AM
geepondy
Jun 23, 2016 12:26 PM
gfrobe
Jan 27, 2013 02:44 PM
Streetzx05
Oct 23, 2012 01:45 PM
The Critic
Apr 20, 2012 11:20 AM
