Gasket falling out of rear windw stop light- how to fix?
Old Dec 29, 2012 | 10:21 PM
mmitsch's Avatar
I have a 2007 Honda Fit Sport and the gasket around the rear window stop light is falling out. This is the light mounted in the middle of the rear window of the hatchback. I am not sure what adhesive I should use, if I should replace it, etc..
Let me know your ideas.
Old Dec 30, 2012 | 01:32 AM
macbuddy's Avatar
I had the same problem. Did you have your rear window tinted? The shop that did mine, removed and replaced that gasket to install the tint. Later, mine fell off too. As a matter of fact, it fell off so many times, I just tossed it. I haven't noticed any problems without it on.
Old Dec 30, 2012 | 04:31 AM
Carbuff2's Avatar
Ours became "loose" with age, also.
I just glued it on with a thin smear of black RTV. It doesn't take much to make it stick.
Old Dec 30, 2012 | 02:07 PM
nosewitdot's Avatar
Same situation here. I've kept mine on though. I only notice it at night when the light bounces off the gasket when I brake.
Old Dec 30, 2012 | 05:16 PM
MarkyMark's Avatar
I just pulled it all the way off and put it back on with some clear RTV. 3 years ago or so, still stuck on there good.
IfChris_ThenFit
Feb 25, 2019 09:28 AM
littleblackcar
Oct 29, 2011 07:36 PM
wwetmor
Apr 6, 2007 03:02 PM
FrogDaddy
Aug 16, 2006 07:09 PM
Dick
Jun 3, 2005 01:06 AM
