Opening the tailgate panel?
Old Jan 10, 2013 | 03:02 AM
dennison's Avatar
Question Opening the tailgate panel?
Can anyone teach me how to remove the panel on the tailgate? I had accidentally pushed the manual unlock cover inside (into the panel) and I cannot get it out without removing the back panel.
Old Jan 10, 2013 | 03:54 AM
jmsplitfyre's Avatar
There are 2 pushclips right by the tailgate latch, push the middle of the clips and pry them out. Then remove the plastic handle on the tailgate. After that, you can just pry the panel starting from the sides, be careful not to pry too hard as you may break the clips.
Old Jan 10, 2013 | 04:52 AM
dennison's Avatar
Thanks for the quick rep! I'll check this out.
Old Jan 12, 2013 | 05:27 AM
dennison's Avatar
So I managed to pry apart the back panel and put it back but I cannot get the plastic handle (pull pocket) to fasten and it keeps falling out. I remember it became loose after I removed the push clips.
How do I put it back? Should I insert plastic handle before fastening the back panel with push clips?
Old Jan 13, 2013 | 02:48 AM
dennison's Avatar
I tried removing the back panel again but the handle still won't stay. Help!
Old Jan 13, 2013 | 04:00 PM
Check the tabs on the handle, maybe it broke off when you took it out. I chipped mine off, but didn't have any issues of it falling off.
Old Jan 14, 2013 | 03:04 PM
dennison's Avatar
The tabs are still there, there doesn't appear to be any chip/broken portions. The tabs aren't that "deep" to begin with, i.e. it's not enough to keep the handle in. Is this normal?
Click for larger image
Old Jan 14, 2013 | 03:38 PM
Weird. Yours is in better shape than mine. How about checking the tabs on the panel itself? As I've said, my handle is kinda loose as well but not to the point that it falls off.
Old Jan 14, 2013 | 04:16 PM
dennison's Avatar
What's keeping your handle in place? Is it the plastic panel or the metal door?
m_x
Feb 4, 2015 03:50 PM
dennison
Jan 31, 2013 09:54 AM
loki0808
Jan 30, 2010 11:09 AM
smatts
Jan 9, 2008 09:07 PM
p1yo2
Apr 20, 2007 11:53 PM
