2005 GD 1 jerky and shuddering at low RPM and CVT slipping???
Old Mar 3, 2013 | 10:50 AM
zentaiknight's Avatar
Ok heres the deal. My car she will b 8 yrs old this may. 230k km mileage so far.
Diligently serviced every 10k.
But recently, ive been experiencing shuddering/ jerking / clutch slip issues!! FML
Shuddering n jerking occurs during 1500-2000 rpm. The whole car literally almost 'harlem shook' a while.
Clutch slip happens when im in cruising speed. Low or high it happens. But all i did was to maintain throttle n it feels like my gear cannot be engaged and clutch slippy. In fact it almost feels like im driving a 4 speed auto??
Cfm driving till she dies. But the drive is pretty suffering...
Recently done oil change.
Sparkies done about 10-15k ago
Tb cleaned.
rims were changed so no balancing issue i guess
So bros out there share share.
Thnx thnx so muchhh
Old Mar 3, 2013 | 12:32 PM
krunk13's Avatar
Its not a clutch. its your Cvt's drive belt most likely.
Old Mar 3, 2013 | 07:37 PM
hi bro, thanx for your reply....wonder if the damage for the belt is high? cos i bought mine from a parallel importer. i have to go to a stockist and buy....
Old Mar 4, 2013 | 12:17 AM
loudbang's Avatar
More likely it's your CVT fluid. Honda changed the formulation awhile back to cure this problem get it changed with the special new Honda fluid.
Old Mar 4, 2013 | 03:32 AM
CVT fluid just changed 100km ago bro....so i don't think it's that....and i change it every 10k km.....
Old Mar 4, 2013 | 04:13 AM
wackyflik's Avatar
Had this jerking problem on 2011. Expect the gearbox had problem. However, 1 guy helped me to find the problem and solved it. It was just my coil plugs problem. So, 7 out of 8 coil plugs create the problem. Solution, change all the coil plugs. Problem solve. My car is 1.4 i-dsi.
Old Mar 5, 2013 | 02:37 AM
loudbang's Avatar
Are you using the latest CVT improved fluid from Honda?
Old Mar 6, 2013 | 12:05 AM
loudbang's Avatar
Here is the way to calibrate the CVT start clutch.
CVT Start Clutch Calibration Procedures (CVT)
Old Mar 11, 2013 | 04:58 AM
hi bros, thanx so much for ur reply, just went to a workshop and he recommended changing the whole cvt gearbox
he said start clutch has a prob.
can i ask how does a start clutch look like?
Old Mar 11, 2013 | 12:25 PM
loudbang's Avatar
It's in the photo in post #2
Honzo
May 4, 2017 09:18 AM
Fitftw15
Nov 10, 2015 01:33 PM
royalflush313
Feb 18, 2011 10:43 AM
phoenity
Sep 12, 2010 08:24 PM
jim beam
Jun 13, 2005 03:26 PM
