Whats the best offset for my 07 fit?!?
Old Aug 4, 2013 | 10:33 AM
DogginMySh*tter10-4's Avatar
i just now bought a 07 honda fit and im trying to make it less girly.
i drive 200 miles a day for work so i sold my 700hp mustang and bought this fit
i need to make it my fit. Fit me a little more
what offset's and rim size fit's best on this car i was looking at some 15in 8in wide +15 offset's and of course ill slam it also
Old Aug 4, 2013 | 09:12 PM
Skytraveler's Avatar
Hi Doggin,
Welcome to FitFreak. Check out this thread here in the Fit Shoes Forum : https://www.fitfreak.net/forums/fit-...questions.html
Also check out this thread to see pics and specs on some of the other member's wheels and tires: https://www.fitfreak.net/forums/fit-...-included.html
Last edited by Skytraveler; Aug 4, 2013 at 09:17 PM. Reason: More information for Doggin
Old Aug 4, 2013 | 09:23 PM
Fit4Trav's Avatar
Do you want to do fender modifications for the wheels to fit without rubbing? Do you care about the tires rubbing on the rear fenders/front fenders?
I had 15x7 +13 and I rarely rubbed with 195/45 Toyo Proxes Tires.
Old Aug 4, 2013 | 10:14 PM
Rubbing don't bother me nor does tire wear I'm pretty good at rolling my fenders.. Just looking in the fender wells there isn't much room for bigger rims if slammed I'm lookingnfor a aggressive look don't care about ride quality
Old Aug 5, 2013 | 01:02 AM
solbrothers's Avatar
What spring rates are you planning on running?
Old Aug 5, 2013 | 08:10 AM
Im going to figure out all that after i select my wheels.
So i can build to fit
Old Aug 6, 2013 | 12:27 PM
myfoxmystere's Avatar
The only colors that I consider "girly" on the 2007 Fit are White and Tidewater Blue. If your Fit has tinted windows, it usually makes it more manly looking. I suggest a rim that has enough metal on it to be quite strong, yet stylish at the same time. The last thing you need is a rim that is stylish but not strong enough to take a bit of punishment while commuting long distances. I've seen some rims that got destroyed by hitting a dip at a moderate speed because they didn't have enough metal to take the shock. Tires with an extremely low profile will also cost you more in gas as well, so a balance with size and style is the key. If your 2007 has a TPMS unit, you'll need to transfer the sensors from your current wheels to the new rims. If not, there are some metal stems that will add style and make it safer at the same time.
Old Aug 6, 2013 | 12:38 PM
Yea..... I bought the car with the windows already tinted. And as for tires im really staying stock rim size just going wider and more aggressive look stock tire size just streached a little.. And im not buying cheap china wheels..
Old Aug 6, 2013 | 02:25 PM
pearl's Avatar
15x7 +35 = win
Old Aug 8, 2013 | 08:31 AM
Originally Posted by pearl
15x7 +35 = win
What im thinking.... Maybe even +25
nsxfit
13
Feb 23, 2020 12:32 AM
Remedi
Jan 11, 2013 07:02 PM
inxsole
Nov 4, 2009 12:55 PM
whtsjdm
Feb 16, 2009 10:40 PM
kurtdesch
Jan 19, 2007 01:22 AM
