Removing the Rubber Spacers to lower the car?
Old Aug 7, 2013 | 11:14 PM
cocomartinreyes's Avatar
Hi guys I've sorted out a cheap alternative way on lowering my car a bit. A car shop suggested removing the rubber spacers on the springs. Is it safe? Has anyone done this setup? If so- how many inches will it drop?
Old Aug 8, 2013 | 05:03 AM
loudbang's Avatar
Noisy and will lower it only the thickness of what ever rubber you take out.
Old Aug 8, 2013 | 08:56 AM
13fit's Avatar
NOT RECOMMENDED
Metal on metal WILL damage each other eventually
Keep the rubber. WIll you honestly notice 1/4 of an inch or so? Thats about how thick it is once the weight of the vehicle is compressing it
Old Aug 8, 2013 | 01:59 PM
Wanderer.'s Avatar
Won't make a noticeable difference and will be noisy.
If you want a cheap alternative cut one coil off your stock springs and keep the rubber isolators.
Old Aug 8, 2013 | 04:41 PM
Juan2Six's Avatar
I think that would be a bad idea... like others have said noisy for sure and metal on metal wear. Those isolators keep the spring from moving around and centred on the inverted spring cups..
I strongly recommend proper lowering springs if on a budget. It shouldn't be hard to find used springs.
Old Aug 8, 2013 | 05:10 PM
Wanderer.'s Avatar
I see them floating around the classifieds for $100 or less sometimes.
I was semi-joking about cutting your stocks, your car won't blow up or anything, but an aftermarket lowering spring is always safer/better.
jonheake
Dec 19, 2023 07:12 PM
kingkelly
Oct 7, 2023 10:45 AM
jazzgirl
Feb 23, 2013 12:07 AM
StinklePink
Dec 14, 2012 05:33 PM
BoomFantastik
Hawaii Community
18
Apr 18, 2009 10:27 PM
