Steering/Trans interlock reset
Old Sep 17, 2013 | 06:39 PM
casandreas's Avatar
Fit gurus,
After R&R of engine:
1. gauges light up
2. steering won't lock
3. key won't release
4. engine won't start
5. shifter stuck in park
When I remove and then connect negative battery cable, the key can be removed and the steering will lock until it is unlocked by the key, which then becomes stuck again.
The manual shifter release works.
I looked for information on this forum on how to reset it.
Any advice and help would be appreciated!
Thanks,
Chris
Old Sep 18, 2013 | 03:31 AM
loudbang's Avatar
Have you checked the brake pedal/ start interlock switch?
Old Sep 22, 2013 | 12:28 AM
casandreas's Avatar
interlock switch
I'll try the switch, thanks!
Old Sep 24, 2013 | 06:54 PM
casandreas's Avatar
Update
The brake switch and the shifter lock servo are good. Still no power to the starter solenoid. The steering locks and transmission unlocks only with a battery disconnect.
Any ideas out there?
Thanks in advance!
Fweemn
May 17, 2023 10:43 PM
FitfulKenny
Dec 4, 2015 09:45 PM
Bronxborn
Jun 9, 2015 10:38 AM
mistersink
Jul 31, 2014 12:38 PM
dtrejo
May 15, 2005 07:30 PM
