A14 maintenance
Old Oct 16, 2013 | 09:58 AM
tdot's Avatar
A14 maintenance
Hi,
Looking at the 'Factory Recommended Maintenance' on the Honda website it says for the '4' to:
-replace spark plugs
-inspect water pump (V6 only), (I know this doesn't apply as it's a 4 cyl.)
-inspect valve clearance
I've called two dealerships. One quoted $230 + tax and the other $523 + tax. The second said something about the timing/drive belt. When I pointed out that the Honda website said it was just replace the plugs and inspect the valve clearance for the '4' part of the inspection they simply said "oh well" it is still going to be $523.
The first dealership also said something about the timing/drive belt.
My question is this. Does the timing/drive belt need to be replaced in this vehicle and if so why doesn't the official Honda website say anything?
Thanks,
T
p.s. I'm a newbie by the way and I'm not even sure it's a GD...it has GD in the VIN so I figured it was???
Old Oct 16, 2013 | 03:08 PM
Gregg's Avatar
The FIT engine has a timing chain, not a belt.
The chain should be good for 150,000 miles at least, and likely in excess of 200,000 miles.
If they are in the engine enough to do the valve settings, it sure would not hurt to have the water pump inspected.
$230 for valve timing and spark plugs sounds like a decent price, for a dealership.
Ask them to throw in the oil change and filter for free, and they have a deal.
Gregg
Old Oct 17, 2013 | 12:55 PM
Marrk's Avatar
Gregg
OT: How do you inspect a water pump, aside from looking for leaks?
Thanks!
Old Oct 17, 2013 | 01:08 PM
Gregg's Avatar
Yes, it is just an outside visual inspection.
Look for corrosion and anything coming out of the weep hole where the shaft enters the pump housing.
Look for coolant stains around the gasket and at the hose connections.
If the belt is off, check for play on the input shaft.
That is about it.
Gregg
Old Oct 17, 2013 | 01:42 PM
Marrk's Avatar
^^Thanks.
Tonyride
Jun 21, 2018 09:24 AM
09FIT101112
Nov 25, 2012 03:55 PM
CarDemon
Oct 28, 2009 02:23 PM
EdgeJD
Jul 25, 2007 08:27 PM
pch
Aug 26, 2005 12:55 AM
