Help Needed for Serpentine Noise
Old Nov 9, 2013 | 01:22 PM
apexanimal's Avatar
I know there are a few serpentine belt threads going, but I wanted to keep those clean and on topic...
I just changed my serp belt and now I have a high pitched whine that grows louder and higher pitched the higher the rpm...
Facts:
-as I started, I found that the alt mounting bolt was very very loose and beginning to back out... It is now tight.
-I installed a dayco poly belt like this one:
Thoughts?
I adjusted it a bit looser from what I had first done, but maybe I need to do more?
Now that the alt is tight, is it transmitting more noise?
The ribs on the belt creating harmonics that weren't previously there?
Did I break something?
Any help and insights are welcome.
Old Nov 9, 2013 | 02:11 PM
Texas Coyote's Avatar
There is always a protective coating on new belts than needs to be washed off before use.. Spray it with a household cleaner like Formula 409 and rinse it with water while the engine is idling.. You may need to do it a couple of times.
Old Nov 9, 2013 | 02:40 PM
apexanimal's Avatar
Windex just as good?
Thanks
Old Nov 9, 2013 | 08:11 PM
apexanimal's Avatar
Used some windex on it and only helped a touch...
But went 45 min to see some family and back and it's much much quieter now... Should go away in a few more days...
Thanks for the assistance
07FitSprt
Feb 24, 2019 09:06 PM
mnapuran
Jun 11, 2016 06:00 PM
myfitfreakacct
Aug 10, 2011 01:51 PM
Marrk
Oct 23, 2009 07:32 PM
gabriel
May 4, 2005 11:16 AM
