Burnt Coil from a 2007 Fit
Old Feb 16, 2014 | 04:17 PM
coldstorage5's Avatar
Hi, I went to put in new rotors, Pads and plugs in the last 2 days. My Fit has 90000 miles on it.
1) Those screws holding the rotors in were horrible. A huge battle to get them out. Had to Bang them then turn , bang turn. terrible.
2) The second plug was very tight. I was worried I would break it. So I shot some wf-40 down there. and went back and forth until I got it out. The plug had some burn signs.
3) The coil looks burnt and discolored.
Any one know why this happens.
I saw a replacement coil on eBay for $16. Do you really think it matter that i get OEM?
Old Feb 16, 2014 | 04:29 PM
2010FitSport's Avatar
Its hard to tell from the pic but it looks like the plug in that coil has marks near where the porcelain meets the metal. Spark plugs can slowly fail and leak combustion gasses through that spot which can be similar in color to what you see on the coil. That hot exhaust leaking could lead to a coil failure over time if it heats the coil too much. It could be that or the coil itself just starting to burn out.
Old Feb 17, 2014 | 10:43 AM
Marrk's Avatar
Originally Posted by coldstorage5
[/URL]
Were you using an impact wrench (the kind you hit with a hammer, not the pistol-grip electric kind) on the rotors? What you are saying is not entirely clear.
People love the idea that "you don't have to replace" things like spark plugs and engine oil for millions and millions of miles. OEMs must be selling cars by the boatload on such ideas. I don't get that.
Old Feb 17, 2014 | 11:52 AM
[QUOTE=Marrk;1223631]Were you using an impact wrench (the kind you hit with a hammer, not the pistol-grip electric kind) on the rotors? What you are saying is not entirely clear.
Yes, Exactly an impact wrench, The first screw ended up getting stripped , the second one, was hit turn, hit turn. The other 2, came right out.
Old Feb 17, 2014 | 11:53 AM
People love the idea that "you don't have to replace" things like spark plugs and engine oil for millions and millions of miles. OEMs must be selling cars by the boatload on such ideas. I don't get that.[/QUOTE]
Don really know what you mean by this comment.
Old Feb 17, 2014 | 12:10 PM
Marrk's Avatar
Don really know what you mean by this comment.[/QUOTE]
Nothing in particular. I wouldn't keep spark plugs for 100k mi (like the book recommends), and I wouldn't let the valves go un-inspected for 105k mi (like the book recommends), and I wouldn't let engine oil go 7.5k mi (like the book recommends).
Your coil pack issue seems unusual, given what I read here and elsewhere.
Old Feb 17, 2014 | 06:38 PM
Yes I change oil with synthetic at 7500,....
I have to tell you, I ran my Fit hard to today, To manhattan, Bronx and the burbs.
It looks like my mileage is dramatically improved. ( I have a plug in spec monitor)
Maybe that Plug was bad for Years. I usually changed plugs every 30, 40K I saw the Fit you could go to 100k.
Im glad I did it. also I did order a new coil for $ 16. Gotta be better than that burnt coil.
Old Feb 17, 2014 | 06:45 PM
Marrk's Avatar
^^Not a bad plan. Might check your air filter, as well.
When did you last do the valves?
Old Feb 17, 2014 | 07:32 PM
Hi I have never done valves, Is it a big Job ? Hard to do?
Old Feb 17, 2014 | 07:37 PM
Marrk's Avatar
A valve adjustment is daunting at first. But it is a one-foot-in-front-of-the-other kind of thing. By the time you do it twice, you will lose all respect for service techs, and you will wonder why you never did it yourself before. If I were there, I would come over and help you.
Old Feb 17, 2014 | 08:00 PM
OK, I google it, I appreciate you offer.
Old Feb 17, 2014 | 08:04 PM
wafflemelon's Avatar
I just adjusted my valves over the weekend, never done anything to a car before, like the guy above said, it seems daunting at first, but as long as you follow a guide, its not too bad. I had help from my Dad, but we used this guide.
DIY adjusting valve clearences GD - Honda Fit Forums
We also checked with his OBD II Reader and found that it said my #1 Valve was misfiring, looked into it and replaced all my spark plugs (for good measure, they were nearing 120k KM) and replaced the #1 Coil Pack, problem solved. We replaced it with an OEM coil pack which is Hitachi brand.
Old Feb 17, 2014 | 08:18 PM
Marrk's Avatar
Old Feb 28, 2014 | 11:16 PM
camivill's Avatar
2011 fit...
I had this VK20 from old GD FIT installed on the GE... once i realized that those were not recommended, i decided to switch back to the OEM sparks. The Pic is what i found. 2 coils were decolored. Also the Spark threads were quite oxydated I would said being very thight. Iused Oil a little bit to soften them, whic was not a good ting to do.. lol
After lots of reading, he heat dispersion ofthe Spark plug if it is not good, or if the spark is loose may cause damage to the coils.
Some people in the threads use IK22 which if i am nt wrong are colder Sparks ( means that can dissipate the heat better, therefore wont over heat the coils....) I ended up buying 2 coils to replace the discolored ones and IK20L which are the sparks recommended in Asia...
I did use dielectric grease from a Tunning Kit from Loctite,which protects the threads of the sparks, and softest the contact between the plug and the coils... also prevents some electric arc or something like that...
The Engine recovered power.
Hondarian
Jan 15, 2017 09:57 PM
Harriswt
Mar 19, 2013 01:56 PM
RCpilotjr
Jun 13, 2012 09:19 PM
Koi
Feb 24, 2010 01:28 AM
jaymiepaige
Feb 25, 2007 03:53 PM
