Radio LCD Problem
Old May 6, 2014 | 11:49 PM
Mochanic's Avatar
Radio LCD Problem
Has anybody had a problem with the stock radio display from a 2007 Sport?
It's backlit, but you can barely see just parts of the LCD. (left side is completely gone, but the right side you can almost make out the last character)
Thanks for the replys!
Old May 7, 2014 | 01:49 AM
Desmond Lamar MacRae's Avatar
It is a 13yo deck. Just get a nice aftermarket deck. Even not a nice one will get u streaming b/t and more settings.
Old May 7, 2014 | 01:57 AM
Mochanic's Avatar
Thanks, but I want to keep it stock. I just need to figure out how to fix it.
Old May 10, 2014 | 11:50 PM
MonkeyMD's Avatar
I've seen the same thing. Seems to be more pronounced in the summer heat than in the cold.
Not sure if there is a cheap fix. Probably just have to replace the whole unit. They're about$80 used on eBay.
Old May 11, 2014 | 12:00 AM
spreadhead's Avatar
What kind of math did you use to get 13 years? If his 07 was purchased in 06 it would be 8 years old (2014 - 2006 = 8).
Old May 11, 2014 | 12:13 AM
spreadhead's Avatar
My display on my 8 year old '07 is starting to get weak too. It's probably not serviceable, without replacing the whole unit. Hey it's an 8 year old car, no worry yet. If you buy one on ebay or other used, be sure to get the security code!
Old May 12, 2014 | 09:38 AM
Fit Charlie's Avatar
A year in Texas is almost twice as hard on you as a year elsewhere?
Old May 13, 2014 | 01:49 PM
myfoxmystere's Avatar
I have the same problem on my 2008 Fit Base. It is heat related. I run the AC With the vents pointed downwards toward the unit to get the display back. A radio repair shop might be able to repair the unit. The display screen is likely the weak culprit. I've seen it happen in a mixing board made by Tascam as well. Heat is an enemy to electronics. I plan to stop by a repair shop to see what can be done.
Old May 13, 2014 | 07:57 PM
ikutoisahobo's Avatar
In Vegas the inside temp of a car is easily 110 degrees fahrenheit in summer. No problems with the unit whatsoever.
Old May 13, 2014 | 11:08 PM
Mochanic's Avatar
Mine in not temperature related, it stays the same no matter what the temps are.
Why do I keep getting message is to short error! Message is way over 10 characters!
Old May 13, 2014 | 11:24 PM
Probably because you have only 4 posts right now. I believe the limit is about 10 posts or so? Not exactly sure.
Old May 14, 2014 | 12:05 AM
Mochanic's Avatar
I figured it out. The IE10 content filter button was turned on which was not allowing any text at all to pass through.
Old May 14, 2014 | 07:34 PM
Off topic but IE10! Really bro!? Chrome and Firefox!
Old May 14, 2014 | 09:06 PM
Mochanic's Avatar
No thanks, been there, done that...
Google is owned by SATAN! I don't need them secretly knowing everything I do. Firefox has more issues than all of them put together!
IE11 sucks for now, but they will get it fixed soon.
Old May 15, 2014 | 07:28 AM
DWils's Avatar
Mochanic where do you live? I'm on the mobile version and can't see if you have if listed and visible on the full site version. I have my old head unit just laying around if you're anywhere near Arizona.
Old May 15, 2014 | 01:05 PM
Mochanic's Avatar
40 miles East of Houston.
Old May 16, 2014 | 04:09 PM
*Batman*'s Avatar
I just bought a 2007 Fit and I'm having the same issue. It also has a big spot right in the middle of the LCD screen which I'm assuming was from some sort of an impact to the screen. I would like to replace it as one of the seek buttons doesn't work. I hope you don't mind me posting this question on your thread, but I thought it would add to the commentary.
Is it worth it to buy a new stock unit or should I just go to an aftermarket system?
Old May 16, 2014 | 04:32 PM
Mochanic's Avatar
Not at all... I just want to figure out why this is happening and how to fix it without having to replace it.
Just for the record, my screen has never been hit in any way, and this happens all the time, so it's not related to temperature.
Old May 16, 2014 | 05:02 PM
.Grimace's Avatar
Mine came with some cheapo Alpine deck that looks like crap. I definitely want to find an OEM one.
I realize this adds nothing to helping you just a random thought to keep it stock :P
Old May 29, 2014 | 10:10 PM
Found out what the LCD problem is!
I'm back with what I believe is the answer to the LCD problem. The LCD display has gone bad. A car radio repair shop looked at my Fit's radio. Honda's faceplate is a proprietary face plate mated to an Alpine header unit. The display is integrated to the bezel. You need to replace the bezel with a new one, and transfer the heating & AC controls to the new bezel. Unfortunately, it's quite an expensive part, so you'll need to shop around a few Honda dealers to get a good price. You'll need to order a volume control knob as well unless you find a way to remove the old one without damaging it.
Anyone else who has this problem in Southern California, the shop I went to for help is Car Radio Repair Center in Garden Grove on Euclid Street and Westminster Avenue, on the Garden Grove/Santa Ana border. I'm going to print this thread and give the owners a copy of it. I told the shop owner about the forum before I had him look at the radio.
