Hey guys im back!
Hey guys im back!
hey guys
i just got my Fit back after a long time, about a year and a half, hoping to get it tuned but couldnt get a reliable tuner. So now its back in my hands, im gonna snoop around and see whats new for GD Fit.
well guys i have the T1R kit but with Ultimate and i got the Disco potato with built engine internals and low compression, at the moment boosting at 6 psi, until i get a proper tuner to bring it up to 15 - 20 psi, and my GD is JDM
ok, i found a tuner, hopefully before the end of the month i shall be gettin an appointment, i will post results and pics. And YES Ikutoisahobo, the block can take it, i dont know about the GEs though
Found him, Hannyah A couple pics of my boosted GD3 - Unofficial Honda FIT Forums
Sorry, I'm on mobile.
i was driving the Fit around today, and at idle my aem wideband is at 13.8 is that ok? i know its suppose to be on 14.7 on idle. And when floored it at WOT its at 11 - 10, and letting go during a shift it goes up to 15 or 17 and comes down again. Anyways im set up for the tuner on Monday at 1900 and he said he will tune it from the beginning, and lets see wat happens
Nice. Be sure to post up dyno graphs.
You want 14.5-15 at idle once it's warmed up. They run a bit rich when cold according to some datalogs.
It will always lean itself out when you let off the throttle so that is normal. Running mid 11 afr during WOT seems to be a common theory with tubers but it depends on who you talk with and what your timing curve is set at.
