P0718 due to Overheating AT engine/Transmission
Old Dec 4, 2014 | 06:52 PM
CuTeBoi's Avatar
I have seen this already:
https://www.fitfreak.net/forums/1st-...honda-fit.html
But my situation is a little different, I can't shift manually using the paddle shifters, but I can definitely go higher than 3rd gear, I can even rev it up and down as normal, but in cruise it doesn't control the gears any more.
This happens on each of my road trips that I do once a year, the first few times, it would occur in the California mountains that would cause me to drive in 3rd gear at 60~70 mph for very long periods of time (20 ~ 40 minutes at a time). This is kind of expected, this last year, I've upgraded and tossed a 12x8" transmission cooler and bypassed the main radiator to make sure I can get more time out of it. Now I can drive in 4th gear at a reasonable 70~80mph for about 2 hours at a time, but after 2 hours, I get the D flashing, and P0718 on the OBD2 scanner.
The transmission cooler is not unbearably hot, but it's hot enough to know it's working. I open the engine bay hood and it's extremely hot with both my radiator fans blowing hard. I'm assuming the P0718 is due to the sensors overheating and not providing speed data to the ECU.
Now my question, how can I get some more air into the engine bay, or provide better cooling to my engine? Going 45mph is not acceptable and would like to get some more endurance out of my car.
TL;DR, please help me cool my engine some more, so that I can endure high speeds at lower gears for longer periods of time, I already have a tranny cooler.
Old Dec 4, 2014 | 07:14 PM
xxryu139xx's Avatar
what do u mean by bypassing your main radiator?
Old Dec 7, 2014 | 11:58 PM
CuTeBoi's Avatar
https://www.fitfreak.net/forums/fit-...kevin1107.html
I bypassed the radiator, and went to the tranny cooler directly.
So, no ideas on how to cool the engine off some more?
Old Dec 15, 2014 | 11:37 PM
CuTeBoi's Avatar
Should I give up trying to get more out of the engine, and give it a break every 4~8 hours on a 24~36 hour driving session?
I was forced to take naps to cool off the engine, that sucks.
Geckster
Jul 24, 2015 11:02 PM
iss407
Aug 7, 2009 11:46 AM
BenW
Dec 26, 2008 06:09 PM
ruknight4ever
Nov 29, 2008 05:35 PM
hqly
Aug 19, 2006 09:44 AM
