O2 Sensor question
Old Jan 8, 2015 | 12:37 PM
tomwilley's Avatar
O2 Sensor question
Hi Guys,
I have a 07 Fit Sport. I have been getting P0420 fault codes and have been diagnosed with bad O2 sensors. I have been looking at costs of sensors about $200 each.
After a bit of research, it seem that I can buy sensors with no connector (open wires.) I can then use the existing connector/wire from the sensors that are on the car and solder them on to the new sensor. I'm pretty comfortable using a soldering iron. These sensors seem to be around $40 each, which is a substantial saving.
I've looked at auto parts warehouse and they've came up with a few parts that look possible. But my problem is some of the sensors have 4 wires and some of them have 3 wires. Of course the website says that they all work for the Honda fit.
4 wire
Replacement USOS-4000 Oxygen Sensor | Auto Parts Warehouse
3 wire
Replacement USOS-3000 Oxygen Sensor | Auto Parts Warehouse
So I have three questions:
1) Has anyone had success with using the sensors without the connectors?
2) Is it the same physical sensor for the primary and secondary sensor?
3) Do the sensors need 4 wires or 3 wires?
Any help or guidance would be appreciated.
Old Jan 8, 2015 | 09:33 PM
MTLian's Avatar
I have a brand new Denso brand 02 sensor that I will gladly sell to you at a good price. I originally bought it when my car threw a pending code but I never got the code again and I had my O2 sensor tested and it was working properly...
It's new in the box and was never installed in any car.
Old Jan 9, 2015 | 08:31 PM
Carbuff2's Avatar
If you look on the rockauto.com site, you will see that upstream and downstream sensors are different.
Honda uses "wide-band" O2 sensors. Folks that have tried to save money with Generic sensors often find that the codes come back.
OE sensors were Denso or NGK (NTK = aftermarket NGK)
R.A. has NTK for ~$90 each. You don't have to risk a bad connection with any home made connections...just sayin'.
Jutboy
15
May 16, 2024 07:11 AM
rwjd
Apr 12, 2024 11:54 AM
dasdavid
Apr 15, 2017 02:39 PM
stubuzz100
Mar 4, 2012 10:15 PM
leonine
Mar 14, 2009 10:51 PM
