Cruise control
Old Jan 11, 2015 | 09:02 AM
Happyinvenice's Avatar
Cruise control
the on/off button is broken. Is it hard to replace? Is there a tech manual to help?
Old Jan 11, 2015 | 01:54 PM
MTLian's Avatar
Is it physcally broken or just won't turn on? According to the service manual you must remove the airbag from the steering wheel the it's only a matter of a few screws to expose the "terminals". If something doesn't work in there, then you have to start checking the wire harness. If all the terminals work, only then do you replace the switch. If your cruise control light doesn't turn on, I think it's probably more of a wiring problem than the physical switch.
Or it could be a trouble code preventing the CC from being activated maybe? Have you plugged in a scanner and checked for pending codes recently?
BobinMO
May 20, 2023 08:24 PM
sdavid12
Dec 4, 2017 08:11 AM
allTRACway
2nd Generation GE8 Specific Fit I.C.E. Sub-Forum
Mar 3, 2016 10:10 PM
marklj
Oct 7, 2014 02:14 PM
Ted Leja
May 4, 2005 11:16 AM
