Why is my mpg 24 - 25?
Old Mar 21, 2015 | 07:41 PM
regieraph's Avatar
Just bought an 08 fit base from some guy and everything runs well besides the back shocks, which still are pretty good, and I tested my mpg driving 60-65 mph and after a full tank I was getting 24-25 mpg!!!! What could be wrong with the car that it's getting that low of mpg? Thank you.
Old Mar 21, 2015 | 08:10 PM
xxryu139xx's Avatar
did u reset the mpg meter before filling up?
Old Mar 21, 2015 | 08:14 PM
regieraph's Avatar
yep that's how I figured out I was getting 24-25 mpg
Old Mar 21, 2015 | 08:24 PM
xxryu139xx's Avatar
what are your driving conditions? city v hway? lead foot? how do u drive?
Old Mar 21, 2015 | 08:26 PM
regieraph's Avatar
Bay Area, California weather, never too hot or cold. Mostly highway driving I would say, never really rev up the engine unless im going on the freeway. Like I said I never really try to rev up past 65 max 70 and I barely do it too.
Old Mar 21, 2015 | 08:32 PM
xxryu139xx's Avatar
maybe do an ecu relearn by resetting it? unhook the battery and let it relearn.
Old Mar 21, 2015 | 08:43 PM
regieraph's Avatar
could it be something wrong with the oil? or engine? or radiator? Btw not familiar with cars lol
Old Mar 21, 2015 | 08:47 PM
regieraph's Avatar
how do i do the ecu relearn?
Old Mar 21, 2015 | 08:48 PM
regieraph's Avatar
i just unhook the battery and rehook? thats it?
Old Mar 21, 2015 | 08:53 PM
xxryu139xx's Avatar
yep, make sure u have the radio code first, u might need a code for the immobilizer. wait for the GD guys to come in and chime in first though.
Old Mar 22, 2015 | 09:23 AM
ragingti's Avatar
Does it have the correct tire size on it? If the tires are the wrong size the odometer won't read correctly and will skew your MPG numbers.
Old Mar 22, 2015 | 10:44 AM
Carbuff2's Avatar
SEARCH Idle Learn Procedure.
How many miles on the car? Maybe it needs maintenance.
Does it idle smoothly when the engine is cold? If not, valve adjustment, plugs, or new coils may be indicated.
Oh, and don't complain about MPG until you use three or four tankfuls of gas. One tank measurements are not always accurate.
Old Mar 22, 2015 | 11:11 AM
Is the car an automatic? If so, your fuel economy will not be great, the 5AT is an inefficient thing when attached to these cars. Ms. 410b has only hit 40 MPG once, and in the cold weather only averaged 29ish.
Also, if you're filling up above 1/4 tank, the MPG will appear worse.
Also, 70 MPH is too fast for optimal fuel economy. And check your tire pressure.
Old Mar 22, 2015 | 02:19 PM
spreadhead's Avatar
Are you actually figuring your milage, or just taking the computer's estimate?
Old Mar 22, 2015 | 03:36 PM
^GD don't give computer estimate.
Old Mar 22, 2015 | 04:08 PM
Hootie's Avatar
Need more information on the vehicle.
I.E.: Transmission, mileage, tire size, known maintenance performed, conditions driven, how it's driven, etc... otherwise we're pretty much taking shots in the dark.
I personally seen as low as 22 MPG with my A/T Sport BEATING IT around town with an autocross day, I've also seen as high as 41 MPG sticking to the speed limit on routes that are mostly highway, and even 33 to 36 MPG hauling a** on the interstate to The Dragon.
Old Mar 22, 2015 | 08:40 PM
Carbuff2's Avatar
The Trail of the Dragon is MUCH TO MUCH FUN to worry about gas mileage while driving it...
Old Mar 22, 2015 | 11:02 PM
Hootie's Avatar
Agreed... Yes some how I managed to get low to mid 30 MPG during the road trip to get THERE (rarely seen under 80 MPH ). Once there, it was a different story.
Old Mar 22, 2015 | 11:05 PM
bati555's Avatar
I have the same mileage ~27-28mpg with 08 Sport Auto, more like 25mpg with ac blasting. Its up to date on regular maintenance and doesn't have rough idle.
I dont store anything in the car to keep it light. I dont exceed 65mph. I will check tire pressure again, they're only a year old. I will unplug the battery as suggested. What is the next thing I need to be looking at?
Old Mar 22, 2015 | 11:10 PM
Are you aggressive on the gas? Do you brake at the last second?
Consider also, the 5AT simply gets worse mileage than the 5MT.
