Axle Nut Torque Specs
Old Apr 10, 2015 | 10:12 PM
GinoLicious's Avatar
Just had to replace axle. I have to torque the nut in the spindle. Cannot find the spec. I know civics go to 134lbs. Any suggestions.
Found my answer. It is 134. The civic is the same spindle nut at 32mm
Old Apr 11, 2015 | 04:03 AM
Mister Coffee's Avatar
Are you sure? 134 seems high.
Old Apr 11, 2015 | 08:00 AM
I have not been able to find a legit answer. 134lbs seems proper. Reasoning behind this is that the axle nut is 32mm on both the Fit and the Civic. The Civic gets torqued to 134lbs so I don't see why the Fit would not.
Old Apr 12, 2015 | 12:26 AM
ragingti's Avatar
134 ft lbs is correct for the front and rear, I looked it up in the shop manual.
Old Apr 12, 2015 | 11:44 AM
Thank you for confirming. I figured it would be the same as a civic.
Old Apr 13, 2015 | 01:28 PM
s0x's Avatar
s0x
That's correct
Yup that's the spec. Ive done this a few times. It seems like a lot but when considering how much is riding on that bolt seems reasonable.
Old Apr 13, 2015 | 01:42 PM
The Acura Cl Type S torques to 181lbs lol
Braug
Apr 8, 2016 04:47 PM
skytree
May 18, 2015 12:45 AM
teamkitty
Nov 15, 2010 09:49 PM
petwhookie
14
Apr 30, 2008 08:25 AM
WaterWatcher
May 4, 2005 11:16 AM
