R18 TB install gives code p2101, faulty actuator
Old Jul 7, 2015 | 11:02 PM
devmail's Avatar
Reinstalled the L15A throttle body and everything is fine again. Sounds like my R18 TB needs replacing. Anyone else get this code, ever?
Old Jul 10, 2015 | 10:12 PM
kylerwho's Avatar
spoon fed
try taking the actuator off the l15a throttle body and putting it on the r18 throttle body. It just sounds like you bought a dead throttle body.
Old Jul 10, 2015 | 10:24 PM
devmail's Avatar
Well the place is sending me a new one no charge. I was going to try what you suggested but the screws have a torx-like bit but with a raised bump in the center, so regular tore bits wouldn't work. Hopefully this new one works and I won't have to try and get the actuator off.
Old Jul 11, 2015 | 05:00 PM
jmsplitfyre's Avatar
How big is the R18 TB compared to our stock ones?
Old Jul 11, 2015 | 06:23 PM
devmail's Avatar
I believe it has a 55 mm butterfly as opposed to our 50 mm. The outlet is 55 mm conpared to 53 mm. Inlet is about the same.
Old Jul 11, 2015 | 07:55 PM
kylerwho's Avatar
spoon fed
They are a security torx bit, much like the same on the seat belt covers.
Old Jul 24, 2015 | 10:27 AM
devmail's Avatar
Cool! Well I got the new throttle body in and it works for the most part, it is giving me another CEL: P1683. From what Ive read this could be in need of adjustment with the idle screw OR another faulty sensor. This is getting annoying, lol. I am going to perform the diagnostic when I get some time.
Myxalplyx
Jun 26, 2015 09:59 PM
Marrk
Sep 14, 2013 01:25 PM
Remould
May 29, 2012 11:39 PM
alf74
Jul 25, 2006 02:30 AM
kimo
Dec 20, 2005 04:12 PM
