Flushing break fluid, what order?
Old Sep 23, 2015 | 01:17 PM
dc9mm's Avatar
Going to flush out the old break fluid and put in new Honda break fluid. But what order do I bleed the breaks. Do I start in the rear say right rear then left rear? I most likely will manually do this with 2 people as I don't have any vacuum pump to pull the fluid out. Unless there's a cheap one I could buy.
2008 Fit sport.
Old Sep 23, 2015 | 01:20 PM
doctordoom's Avatar
Supervillain
I remember it being front driver side, then clockwise (front passenger side, rear passenger side, rear driver side).
Old Sep 23, 2015 | 02:57 PM
dc9mm's Avatar
any Idea on how many bottles
Any idea on how many bottles of honda break fluid is needed. I went to dealer today and bought 2 but thinking I may need at least 3 bottles. There about 12 ounces in size about the size of a can of pop.
Old Sep 23, 2015 | 04:26 PM
MTLian's Avatar
I recommend using brake fluid instead of "break fluid" beer is a good fluid for breaks
I flushed the clutch and all the brakes and just barely got by with 2 cans. I recommend buying three and see if you can make do with two. As long as you don't open the third can, it'll be good for years to come
Old Sep 23, 2015 | 11:08 PM
dc9mm's Avatar
ok thanks
Yepp BRAKE fluid. I will pick up a third just in case.
JerryHughes
Jul 13, 2019 11:09 AM
JerryHughes
Apr 10, 2019 11:33 AM
fitowner10
Sep 9, 2014 08:36 PM
xander
Feb 2, 2009 01:50 PM
Kofi Anim-Appiah
Aug 6, 2005 04:43 PM
