Rear end "loose" or "floaty" over bumps
Old Dec 19, 2015 | 11:17 PM
jim12i's Avatar
I've got a 2007 Sport, and my college-age son just purchased a 2007 Sport as well.
He mentioned that the back end feels loose on bumps. I rode with him to the hardware store today and felt it. On bad expansion joints (common in Michigan) or speed bumps, it feels like the rear gets kicked to the side an inch or so, as well as the expected bump going up. Its somewhat disconcerting, and seems like it could be a safety issue if he hit a bump while cornering.
I assume something is worn or broken in the rear suspension, but haven't had a chance to look yet, as he just got back from school.
Any advice on what to look for? Has anyone else experienced this?
Thanks.
Old Dec 20, 2015 | 02:36 AM
khorton21's Avatar
Old Dec 20, 2015 | 11:09 AM
apexanimal's Avatar
the rear roll stiffness is also very very soft in this car as well... do check for worn bushings, but increasing the spring stiffness, adding a rear roll bar, and lower profile tires will all help decrease what you're experiencing...
Old Dec 21, 2015 | 11:30 PM
Foiled's Avatar
on my 07 Fit, the rear end moves all over the place on bumpy roads like you mention. I believe it is the rear torsion bar (axle) bushings. The shop I normally go to said they look fine.
I'm getting a suspension shop to look at it for a second opinion.
When I jack up the rear of the Fit and get under it, I can use a pry bar and make the rear axle move back and forth (side to side) about an inch. When I do this, I can see the bushings moving as if (the rubber inside the bushing) are broke. I don't believe the rear bushings should move like this and that is the reason for all the movement in the rear of the vehicle.
I have my next appointment for the axle on Monday and I'll report what I learn then.
Old Dec 22, 2015 | 04:17 AM
kylerwho's Avatar
spoon fed
completely agree with apexanimal, in addition look into adding a rear sway bar or adding wheel spacers to widen the rear wheel track to help add stability.
Old Dec 22, 2015 | 11:33 AM
gdup4rmftup's Avatar
A set of lowering springs will cure that!
Old Dec 23, 2015 | 08:05 PM
vap3's Avatar
you guys are crazy! with the 14 inch steeles and stock suspension I haven't even reached the limits yet and I conserve my momentum like crazy when cornering!
Old Dec 24, 2015 | 10:08 AM
Foiled's Avatar
I replaced the rear shocks a couple days ago and I notice a significant difference in the floaty rear end. I believe the floaty problem may have been solved by the shock replacement. The right rear shock was not working and so I was just riding on the spring on right rear. I couldn't tell the shock was bad until I removed it and pushed in, pulled out on it. I am still going to have the rear bushings checked but so far so good.
Old Dec 24, 2015 | 09:24 PM
vap3's Avatar
^ so the ride height was ok? it wasn't sagging or anything?
Old Dec 25, 2015 | 11:02 AM
Foiled's Avatar
I'll look at that on Monday and let you know!
Old Dec 26, 2015 | 03:02 PM
Carbuff2's Avatar
Shock absorbers do NOT affect ride height.
Old Dec 26, 2015 | 03:18 PM
Foiled's Avatar
Yes, I understand that.
Old Sep 25, 2023 | 12:08 AM
Gd3jordan's Avatar
Thanks.
did you ever find out what the problem was?
Old Sep 25, 2023 | 12:15 AM
Gd3jordan's Avatar
did the rear shock replacement fix the rear end kicking out while hitting a bump in a corner?
Old Sep 26, 2023 | 02:17 PM
mifesto's Avatar
had similiar floaty feel for my gd3, replaced rear with KYB and did rear sway bar and it made a huge difference.
Old Sep 27, 2023 | 12:16 AM
Gd3jordan's Avatar
@mifesto i just ordered a set of KYBs for the rear of my car, hopefully that improves it.
utsug
Oct 6, 2023 02:15 PM
Myxalplyx
Racing
24
May 22, 2015 02:36 PM
hayden
18
Apr 30, 2012 12:12 PM
DrKelso
Sep 12, 2009 06:36 PM
pwnstar
Oct 15, 2008 09:27 PM
