changing the stock antenna/wiring on GD1
Old Feb 26, 2016 | 06:54 AM
InsaneGenius's Avatar
I have an issue after changing the stock cd player to a double din and the wiring seems to be weak I should of just bought an adaptor but anyway, I can't seem to get a decent connection with a solder type antenna plug and when I do its fuzzy, there's 1 pair of wires which is the reception then there's a wire by itself for the booster but connecting it to 12v positive does nothing to 'better' the reception?
The wire seems to be to thin for my plug so my only option is to replace the wiring for thicker wiring how hard would it be to pull new wiring? and has anyone connected the booster correctly or just by pass it?
Old Mar 1, 2016 | 12:31 AM
Never mind I was able to run new radio wiring only took about 10 mins also bypassing the booster did the trick.
vwli
2nd Generation GE8 Specific Fit I.C.E. Sub-Forum
Oct 4, 2013 07:43 PM
WeaponR23
Jul 28, 2011 05:06 PM
Rod2Rice
Jul 22, 2010 11:47 AM
vwli
Jun 25, 2009 09:41 PM
GodSpeed
Jun 19, 2009 04:24 PM
