Metra 40-HD10 Antenna Adapter Question
Old Jun 25, 2009 | 09:58 AM
vwli's Avatar
I recently installed an aftermarket HU on my Fit Sport. It is having a lot of static when I am listening to FM radio. I wonder I hooked it up correctly or not. On the Metra 40-HD10 antenna harness, besides the regular antenna cable, there is another wire. I connected it to the HU wire labelled "antenna power supply". Did I do it correctly?
Old Jun 25, 2009 | 05:38 PM
on my GD i used Metra 40-H20...
that wire's for power antenna's no? (the ancient antennas where it extends when u turn on the radio)
Old Jun 25, 2009 | 07:15 PM
vwli's Avatar
I remember seeing one thread somewhere saying the GE antenna has a power booster. And I thought that is what the wire for and that is why I connected the way I described.
Old Jun 25, 2009 | 09:41 PM
DDsaluki's Avatar
I had the same question while installing mine. From what I understand, the wire on the car side harness that says "antenna" is a signal wire for power extension, and only provides momentary power. The antenna power on the HU side provides constant power when the HU is on. This could vary depending on your HU though, so YMMV.
If in doubt, you could always wire the antenna power lead to the 12volt acc line (red on the car side harness I think), which would power the antena whenever the car is on.
NjBlazin07
Feb 15, 2020 05:20 PM
vwli
2nd Generation GE8 Specific Fit I.C.E. Sub-Forum
Oct 4, 2013 07:43 PM
WeaponR23
Jul 28, 2011 05:06 PM
Rod2Rice
Jul 22, 2010 11:47 AM
GodSpeed
Jun 19, 2009 04:24 PM
