Engine replacement 07to 08
Old Apr 23, 2016 | 02:38 AM
Seantipling87's Avatar
So I through rods and replaced the whole engine but with 08 model both identical. All done but won't start. Are there codes I need to enter or what's my next step
Old Apr 24, 2016 | 08:54 PM
doctor J's Avatar
No codes needed if only long block is changed. Even if throttle body is transferred from the donor car the engine may run poorly if TP sensor is messed up but it should start.
I am guessing the replacement engine has issues too
Old Apr 25, 2016 | 08:07 AM
kylerwho's Avatar
spoon fed
not enough information here.
Is it cranking over?
Where is the new motor from?
willy65000
May 25, 2017 06:57 AM
kinosh
Jan 9, 2017 07:38 PM
phenoyz
Nov 11, 2016 01:34 AM
MMurray
Oct 8, 2010 03:49 PM
Spooling
Jul 21, 2009 10:54 PM
