Idler Pulley Hardware 2008 Fit Sport
Old May 25, 2016 | 07:42 PM
Ailur's Avatar
Long story short, I replaced the idler pulley and the drive belt. Had everything looking good, and I went for a test drive. A mile down the road, the pulley bailed out. I couldn't find it anywhere in the field next to the road, and the mounting hardware went with it.
Getting a new pulley isn't a big deal, about $25. The problem I have is that no one seems to sell the hardware (bolt, front plate, collar, washer). No idler pulley brands include the hardware that I can see. Has anyone ever had this problem? I can't even find part numbers.
Old May 25, 2016 | 07:59 PM
Ailur's Avatar
Found them. Apparently Honda thinks an idler pulley is an air conditioning component instead of an engine component. I disagree.
Old May 31, 2016 | 09:56 PM
fit2bking's Avatar
How did it bail out? sounds like you forgot to put the collar on.
Old Jun 1, 2016 | 09:52 AM
Carbuff2's Avatar
We rejected buying one aftermarket idler puller after seeing that it was dimensionally imperfect (<--- that's another word for cr*p)
It was a 'name brand' too.
There was no collar...it was designed to just bolt on (and bind)
So, let the buyer beware. Often, factory parts are better ... if you can afford it.
Old Oct 26, 2016 | 07:51 PM
KwazyKwaig's Avatar
spell check is worthless
OK- "Idler puller"? I never heard of that part. Sounds more like a tool. I think you mean idler pulley. But I am happy to learn Honda considers the serpentine belt idler pulley to be part of the A/C system. Until now have been unable to find any info in the factory shop manual. I was looking in the section about the alternator and belt replacement. Found nothing. Nice job Honda!
Old Oct 27, 2016 | 06:48 AM
Carbuff2's Avatar
Yes Idler PULLEY. Darn autocorrect!
Giovanny Alan Alvarado
Apr 27, 2025 01:09 AM
99ls1tj
Sep 21, 2018 10:00 PM
jilm
Apr 13, 2016 06:22 PM
running
Apr 5, 2014 12:11 AM
justinreigle (at) gmail (dot) com
May 4, 2005 11:16 AM
