Blown out spark plug? Cylinder head remove/install??
Old Jun 17, 2016 | 08:11 PM
Fissel's Avatar
Hello all,
I've got a 2008 Fit with about 92k miles. Last Fall a spark plug came loose & I replaced all of them. Now the same one came loose again, except this time it exploded out violently taking the threads with it. I'm assuming the threads were damaged when it came loose previously but it took torque and lasted in there for about 4 months & 5k miles.
Anyway I found the removal & install instruction (Cylinder Head Removal (L12A/L13A) & Cylinder Head Installation (L12A/L13A)) here which is super helpful BUT A FEW QUESTIONS........
1. Can I pull the head in the chassis? Or must the engine be pulled?
2. Looks like Honda sells a gasket set (06110-RME-A00) for the cylinder head, will this have everything I need? Can't find a breakdown of whats included.
3. Any idea how long it'll take me to pull & re-install the head? Best case scenario? I'm a 7-level aircraft mechanic, formerly ASE Diesel Master Tech & built motorcycle engines for years, so I'm pretty handy.... (Once I get the head out I've got a machinist who'll heli-coil the threads while I wait.)
Thanks all for the help.
-Fissel
Old Jun 17, 2016 | 09:02 PM
doctor J's Avatar
On 1.5 engine the head can be pulled with engine in; the timing chain must be match marked to the cam sprocket before removal. Plan about 10 hours for Removal and installation process
Old Jun 17, 2016 | 10:25 PM
dwtaylorpdx's Avatar
1. Head will come out in the car.
2. There are two part numbers one is just the head gasket one is the top-end-kit. I've had really good luck on imports with NAPA kits(Usually TRW inside, sometimes you'll find the factory set in the factory box inside the napa box) .. If you can't get the OEM.
3. First time around I'd go more like 6 hours for the work.. with air tools to break everything loose I'm pretty sure I could have it off in a couple hours. (Similar resume to yours but all track time... ) The biggest thing is documenting all the electrical connections that are close or in the way..
Seriously the head is easy to get at and if you've worked on planes and trucks its just another head. I personally have a 100K limit on pulling a head and NOT freshening the engine (Light quick hone, new rings and rod/main bearings). by the time you get all the honda crap off the top of the engine its darn near out and I'm pretty sure two guys could pole lift it out.. I'd also check around on the cost of a reman head rather than helicoil it. Ive occasionally been surprised how cheap the heads are from NAPA or other major auto parts stores.
Old Jun 18, 2016 | 09:23 AM
Fissel's Avatar
Alrighty, Thanks for the input. I'm going to the dealer now for the gasket set & I'll get to work once it comes in.
-Fissel
Old Jun 21, 2016 | 10:38 PM
Fissel's Avatar
Got started this evening after work & got the coolant drained, intake removed, all required wiring disconnected/removed, fuel rail/injectors removed & heat shield popped off. Hope to finish getting the head off tomorrow. Lotsa sensors to remember to plug back in....
Complete top end gasket set is backordered with no eta so it looks like I'll have to order individual gaskets piecemeal.
Old Jun 22, 2016 | 08:37 PM
Fissel's Avatar
Any tricks for removing the Crank pulley? Do I really need the three Honda-specific tools which cost a combined $210??
Crankshaft Pulley Removal and Installation
Old Jun 22, 2016 | 08:55 PM
Fissel's Avatar
A little more research & I found this
which led to me ordering this https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Should be in by Saturday and I'll get back at it.
Old Jun 23, 2016 | 04:17 AM
kurobaxkaito's Avatar
Had the same issue where the spark plug blew out on the freeway and took out the threads from my 3rd cylinder. Went through the same exact thing you're going through right now. Where I live, I was able to rent that tool from O'Reilly's.
Old Jun 23, 2016 | 07:17 AM
doctor J's Avatar
Very important:before removal of timing chain, mark the chain to cam and crank sprockets!! Then align the marks during re-assembly and watch them during installation of the chain guides!This will eliminate chain slack and prevent timing to be off after re-assembly
Old Jun 23, 2016 | 05:12 PM
^^ - Listen to him. I actually messed up the timing when working on my car and the car wouldn't start. Had to re-do the whole thing which was a huge waste of time.
Here's pictures I took for reference after I finally got it right. There are different color links and arrows to help you align them. Make sure you get your TDC.
Cam
Crank
Attached Thumbnails Blown out spark plug? Cylinder head remove/install??-80-20131206_192129_78844c9b953853527a12947107a36ad242cf4294.jpg   Blown out spark plug? Cylinder head remove/install??-80-20131206_190924_0d42c95449d1c1bb302989318c64bf3f55d18e28.jpg
Old Jun 23, 2016 | 05:39 PM
doctor J's Avatar
This issue ("slack on the tension side") is quite common when doing timing belts too.
This is why good quality belts and chains are having reference marks for proper installation
Old Jun 23, 2016 | 06:37 PM
Fissel's Avatar
Hmmm, it was my third cylinder too....
How close is your VIN to JHMGD374X8S069449, wonder if the torque settings were wonkers that day/week at the factory or something?
Old Jun 23, 2016 | 06:38 PM
Fissel's Avatar
And yes, I will definitely go out of my way to mark everything.
Old Jun 24, 2016 | 04:04 PM
My is pretty similar I suppose.
JHMGD3 is the same (as it should be) then it's
7668S
8 should be the year and S should be the manufacturing plant I think.
Anyways, my car is 2008 Sport M/T
Old Jun 24, 2016 | 07:10 PM
doctor J's Avatar
I was performing spark plug change at 63 k miles on 2001 Mazda Tribute V-6. Out of 6 plugs 2 were too tight and one was not tightened all the way. The engine has taper (not gasket, which is more forgiving to toque variation due to the larger "bearing area") type plug seat,
So I used small torque wrench rented from Autozone (and everyone was laughing about it) to torque the new plugs.
Old Jun 24, 2016 | 10:07 PM
Fissel's Avatar
It was the factory installed plug that came loose last fall, then when I re-installed them I used a torque wrench which had been calibrated about 3 months prior (I'm an aircraft mechanic & we have to torque EVERYTHING)
But yeah, I wish Honda had properly torqued the original plugs.
Old Aug 4, 2016 | 10:04 PM
Fissel's Avatar
Soooooo.......
After waiting nearly three weeks for the head gasket to come off backorder, then going on my Summer sailing trip I finally got time this week to get it all back together.
Shit started right up & seemed to run as normal, THEN LIKE TWO MINUTES INTO WARMING UP IT SPUTTERED AND DIED, AND NOW IT WON'T RESTART.
I was pretty beat so I called it a night, going to try to go over everything (sensors & stuff?) tomorrow but if anyone's got a pointer it'd be appreciated.
Old Aug 4, 2016 | 11:22 PM
doctor J's Avatar
pull the valve cover and check for the cam timing.
if normal fuel delivery issue is the second suspect
Old Aug 5, 2016 | 04:32 PM
Fissel's Avatar
Doesn't seem to be the timing. Got tickets to the Benavidez vs Douglin boxing match up in Philly tonight & have dinner plans tomorrow so hope to check it out further Sunday.
Any pointers on diagnosing a fuel injection issue???
Old Aug 5, 2016 | 10:43 PM
doctor J's Avatar
Using scanner make sure you got signal from crank sensor (rpms) and cam sensor (timing ) while cranking.
