P0420 and emissions test failed
Old Nov 24, 2016 | 09:53 AM
mind111's Avatar
Hi to all.
Today did not passed periodical servicing
Emissions test failed.
CO should be 0.2, is 0.7.
Sometimes I receive error P0420.
Does it means my catalyst is dead?
Would like to be sure before investing money.
Obtained OBD reader and checked O2 sensors.
Received some data but do not have knowledge to read them.
Maybe somebody here can?
Attached Thumbnails P0420 and emissions test failed-screen.png   P0420 and emissions test failed-screen1.png
Old Nov 24, 2016 | 01:00 PM
doctor J's Avatar
the output of second O2 sensor (voltage) should be pretty steady (around 0.6 volts); on your test it fluctuates almost the same as primary sensor. So looks like catalyst is not doing its job at the time of testing maybe too cold. If your scanner can get catalytic converter temperature post it here (it should be higher than 250 degrees C)
Old Nov 25, 2016 | 03:43 AM
mind111's Avatar
Catalyst temperature is not available in program I have.
Looks that you were right that car was to cold.
After driving for some time graph looks different.
Adding idle print screen.
Moreover, today was at car service, they measured emissions and say that cannot see anything wrong.
Will try to pass periodical servicing again, wish me luck.
P.S. that still leave random P0420 as problem not solved, it appear once in two months.
Jutboy
15
May 16, 2024 07:11 AM
georgi6
Apr 23, 2019 07:49 PM
apexanimal
Feb 22, 2016 11:51 AM
Clydesdale
May 4, 2012 07:20 PM
jkandell
May 7, 2007 09:08 AM
