Power flickering/cutting out while my 2007 fit is trying to turn?
Old Dec 7, 2016 | 10:09 PM
Gula's Avatar
I have a 2007 Honda Fit Sport. I was pulling in to a parking spot tonight and noticed that the power in my car started to flicker when my wheel was turned at the extremities, (was performing a very low speed sharp turn to get in to a space, nothing crazy). The power went in and out a few times. Backed out of the space and did it again just to make sure it was something predictable and that I could reproduce it... sure did, something perhaps with the power steering?
I did just have work done about a week ago from a trusted mechanic. They worked on replacing the alternator drive belt, among some other things relatively minor (headlight thing I didn't have time for, wheel shake, etc). Any thoughts on what could cause this type of power fluctuations? I had the heater running at a very minor level, fan on 1 speed. I have not noticed this fluctuation before tonight, but it was very apparent tonight.
Old Dec 7, 2016 | 11:08 PM
ezone's Avatar
Probably normal. The power steering is all electric and can use A LOT of electricity when it gives assist.
Same would happen if you pull on the window switches while the windows are already rolled up. Lots of load on the electrical system can be seen as dimming lights.
You could attach a voltmeter and monitor the charging system as you drive around, just for assurance that it's working. Or not working.
Old Dec 8, 2016 | 01:30 AM
Gula's Avatar
This is like, mass power drop. Not just a simple dimming. Its pretty substantial.
Old Dec 8, 2016 | 08:40 AM
Carbuff2's Avatar
There's always the possibility that they didn't fully tighten a battery terminal connection, giving you a high resistance when there is a lot of draw (EG, powering the electric PS). So the 'usual' troubleshooting steps apply: Checking all connections for tightness and/or corrosion, being sure that battery electrolyte is topped up, etc.
Bring it back to the shop that did the work. They can check the connections, perhaps put a load test on the charging system while turning...
superslurpee
Aug 3, 2024 04:58 PM
Fit240
Jul 25, 2017 03:09 PM
jdzz
Feb 28, 2011 12:34 PM
fitinit07
Jan 23, 2008 12:57 AM
disallow
May 4, 2005 04:44 PM
