1st Gen Fit engine swap performance thread
Old Jan 2, 2018 | 04:27 AM
  #41
Tedjamin's Avatar
Any news or word from Hasport on this? Exciting.
Old Jan 12, 2018 | 11:36 PM
  #42
FREAKnFIT's Avatar
Following....
Old Jan 28, 2018 | 08:20 AM
  #43
willieblaze's Avatar
Thumbs up
Following!!!!!!
Old Jan 28, 2018 | 08:21 AM
  #44
How much was the BC Coilovers? thats the first thing I want to do then Rear disk Conversion. how much did that cost as well....thank you
Old Jan 30, 2018 | 09:03 AM
  #45
Brian Hasty's Avatar
OK sorry for the delay in posting the latest on the swap. Hasport has been working on a couple other projects, but has now gotten the Fit into the shop and has pulled the engine/trans and are installing the K series engine. It should be up and running in the next several days. I will be going over today to take a few pics. Once we have it running I'll be driving it around until we can get the L15B Turbo swap ready to go in. We're looking for a 6 speed swap so that may take of bit of seaching/waiting until one comes available.
Old Jan 30, 2018 | 09:05 AM
  #46
I bought them at a dealer discount so I can't say exactly how much you'd pay for them, plus I got the DR series so that added a bit. Contact Heel-Toe Auto and check on what they can do for you.
Old Jan 30, 2018 | 09:07 AM
  #47
Originally Posted by benchph
Nice build man!
Where did the rear disc parts came from?
Sorry for the delay been out of town. We build the rear disc conversion kit, using OEM parts. Check the Fastbrakes website for more into.
Old Jan 30, 2018 | 09:22 AM
  #48
Next up for the Fit is taking the seats to get them redone with the Civic Si cushions and backs. Also picked up an Si steering wheel that we'll be installing.
Old Jan 30, 2018 | 09:25 AM
  #49
GAFIT's Avatar
Nice!
Any update on parking brake cable adapters for RSX calipers?
Old Jan 30, 2018 | 04:27 PM
  #50
Tedjamin's Avatar
I guess I misunderstood what you were trying to get across in your above update. I thought the Fit was going into Hasport to design the mounts for the L15 turbo swap. Am I missing something?
Thanks for update!
Old Jan 30, 2018 | 05:24 PM
  #51
GAFIT's Avatar
Hasport is working on improving the K swap mounts first and then will be creating the L15 mounts.
Car is being used as a test mule while at Hasport.
Old Jan 31, 2018 | 04:14 PM
  #52
gd3_guy's Avatar
Cant wait to see how both swaps turn out, and hoping for more innovation on fit K swaps.
Old Feb 7, 2018 | 12:43 PM
  #53
Pics of test fit of the L15B
Old Feb 7, 2018 | 12:45 PM
  #54
Looks like we will have to move a couple of things to get enough clearance for the fans.
Old Feb 7, 2018 | 02:12 PM
  #55
devmail's Avatar
cool! It's definitely not a pretty engine, but factory turbocharged is awesome.
Old Feb 8, 2018 | 05:40 AM
  #56
I am military hopefully that will help. thank you.
Old Feb 8, 2018 | 06:54 PM
  #57
perkidddoh's Avatar
this is great news! I am subscribed!
Old Feb 10, 2018 | 09:20 AM
  #58
W
e test fitted the new cable ends using the stock cables as this seemed like the easier solution than using the RSX cables. Pic of new bracket attached. We will probably make new brackets for the RSX cables as well for those who have already purchased that cable type.
Old Feb 10, 2018 | 09:25 AM
  #59
Also had to do some minor mods to the axle area for the lower shock mount, putting a dent in the axle and grinding a notch to allow the shock to fit into the lower mount. The BC shock body is just slightly too large. I suspect the JDM Fit has a slightly different axle.
Old Feb 10, 2018 | 09:29 AM
  #60
Next up is the install of the cowl to fender braces. Here again the USDM Fit must be slightly different than the JDM Fit as we have to weld a .090 steel template with welded nuts to the fender area in order to bolt the brace in place since there's no way to access the nuts from inside the fender rail. Pics to follow.
