Whats the latest options on replacement headlights?
Old Aug 30, 2017 | 02:37 PM
User1's Avatar
Hello all,
I'm trying to get up to speed on Fits. So basically ANY info is good info for me.
Whats the latest suggestions on replacing the headlights? Looks like mine are getting there as they've seen almost 200k. So am looking at replacing the lights eventually.
I'm hoping to one day do the conversion ---->
Old Aug 30, 2017 | 02:51 PM
GAFIT's Avatar
Have you tried polishing them? You'd be surprised at how horrible they can look and still be recovered with serious polishing and coating.
Here's a pic of ours from a few days ago...
Old Aug 30, 2017 | 04:44 PM
User1's Avatar
LOL I'll probably start looking that direction when I find out how much replacement lights are! BTW, what did you use? Is there like a default standard method and compound, or is it all over the board?
Oh yeah, your Fit is looking good!
Old Aug 30, 2017 | 05:02 PM
GAFIT's Avatar
It is ALL over the board. Literally any abrasive will work followed by polishing and then a good UV protectant to keep them from turning again.
Once you polish them the first time, they will turn even faster if not protected.
This last go around I wet sanded them with 2000 grit wet/dry sand paper and then hand polished them with Meguiars medium cut cleaner, then fine cut cleaner, and then swirl remover. Final step was to coat them with Meguiars Headlight coating.
Prior to using the Meguiars coating I was using various sealants and waxes to provide the UV protection, but none lasted very long. I'm liking the Meguiars headlight coating because it's more like a clear coat that also adds back shine. Key is you have to either fully tape and mask the area or spray the headlights with them removed because it's clear coat. Wife and I can pull the front bumper and lights off so fast now that we just did them off the car.
You can literally use any kind of polishing method though. There are kits you use with a drill, you can use a dremel with a buffing wheel, you can use actual plastic compounds, you can do by hand or with a rotary, etc. I've even heard of using toothpaste.
Last set of headlights I did (father in-laws Acura TSX), I was in a hurry so I just grabbed my rotary and let it eat with compound and then finishing polish. That's the fastest method, but requires tools and is not as safe as doing by hand.
Old Sep 1, 2017 | 09:43 AM
doctor J's Avatar
Thanks for the info.
However, I will only do this procedure (as well as re-uninstalling the hub caps) at the day before trade-in. I don't want my car to "stand out" due to number of reasons beyond this forum
Old Mar 20, 2018 | 03:31 PM
GQ_Style's Avatar
I hear you can bake them in the over at 200 degrees F and open them up to retrofit H1 projectors into them. With projectors you can then use HID's safely and have a clean cutoff. The retrofits have a high beam flap as well. Not seeing too many Fit owners do this yet.
Old Mar 26, 2018 | 08:22 AM
carid's Avatar
Former Vendor
Hi everyone,
I decided to step in and offer several cost-effective alternatives to OE headlights. We carry several replacement headlight options for the 1st-gen Fit. You can view the list by following the link below:
2007 Honda Fit headlights at CARiD (you can change the year if needed).
As an option, you may want to add a protective film on the plastic lens to protect the new lights from fading and further damage. Here are two options available for the '07 Fit:
Clear headlight and fog light protection kit by Xpel at CARiD
LampGard clear headlight and fog light protection kit by WeatherTech at CARiD
Old Mar 27, 2018 | 07:05 AM
Carbuff2's Avatar
^^^ NICE that you have several colored housings!
short1
Jun 29, 2013 12:38 PM
fujisawa
Sep 26, 2012 11:37 PM
theindiearmy
Feb 5, 2011 01:01 PM
doogiefish
Jan 24, 2007 11:58 PM
tiF adnoH
Jun 6, 2006 05:45 PM
