Replaced bad ignition Coil and still stutters, help
Old Nov 9, 2017 | 11:07 AM
cman548's Avatar
I've had the valves adjusted every 110,000. Car is still a little groggy but not near stalling. the AC really drags it down whilst idling.
Old Nov 9, 2017 | 11:05 PM
dwtaylorpdx's Avatar
Plugs/Coils/Valve adjust between 60 and 80 K depending on Low or high speed operation. JUST DO IT its a maintenance item.. Solid valve train needs regular love.. All waiting does is means you get caught when its least convenient ...
Plugs really should be inspected every 20K or so and checked that they are not loose.. Its too easy to do to (< 30 minutes) to let a plug blow out and destroy/damage the head.. Which is a real issue on the fit.
Old Mar 24, 2018 | 10:36 PM
GQ_Style's Avatar
I found a I found a considerable amount of residue and oxidation on the ignition coil boots inside specifically on the spring contacts. As a free option, consider cleaning it out with some isopropyl alcohol to see if that restores your original electrical conductivity. It's a heavy amount of white powdery oxidation residue that I'm sure isn't helping the electrical conductivity. Just be careful because the plastic has gotten a bit more brittle after years of heat exposure.
zrkd51
Feb 9, 2022 09:10 AM
Letsclique
Jun 3, 2015 08:07 PM
RomeoJunior
Oct 20, 2014 03:38 PM
wackyflik
Sep 22, 2014 09:39 AM
radwerx
Aug 26, 2013 06:39 PM
