brake light/tail light bulb
Old Apr 20, 2018 | 06:04 PM
wyndotte1947's Avatar
Hi All,
We have a 2007 Fit on which the combined tail light/brake light bulb has failed. The local auto parts store show that it uses a 7443. This is incorrect. They are huge by comparison with the original bulb, which has no part #. It is a dual filament baseless mini-bulb. The owners manual says it is dual 21 and 5 watt. Can anyone help?
Thanks in advance,
Dave
Old Apr 20, 2018 | 07:38 PM
ezone's Avatar
Check the side that still works and compare, maybe someone stuffed an incorrect bulb and/or socket in the side that doesn't work.
Honda parts catalog says bulb # 34906-ST5-003
Equivalent should be #7443
Remove your bad bulb.
Carry it into the local parts store.
Have them match it up.
Carry your bulb into your local Honda dealer and get a replacement.
Old Apr 21, 2018 | 09:14 AM
Carbuff2's Avatar
7443 is the correct cross-ref.
Agree with ezone. I would buy a 2-pack of bulbs & replace both sides. Instead of showing a parts store the confusing bulb which may be the wrong one, either bring the other-side bulb in, or just buy some 7443s.
Old Jul 17, 2024 | 05:00 PM
Odie707's Avatar
Originally Posted by wyndotte1947
Hi All,
Thanks in advance,
Dave
Sorry for resurrecting this thread, just wanted to add the solution I found after buying the wrong bulb twice. This thread came up when I was searching the web for my answer.
I also had my "tail light/brake light" burn out. The bulb that I needed is bulb 2825, which is the top light in the tail light assembly. (looking at the honda parts diagram for the housing, I could not find a part number, but it is labeled part 17) It is the light that only is used when you lock/unlock the car, or when you hit the brakes it lights up with the main tail light (bulb 7443). The light bulb is about 1/3 the size of the 7443.
Have a good one!
Sujeto
Oct 20, 2016 05:52 PM
Stringer
Sep 24, 2015 05:57 PM
kbh
Dec 7, 2013 03:00 PM
cjecpa
Feb 17, 2013 10:15 PM
drock305
Feb 9, 2010 08:06 PM
