Possible Strange Electric Problem?
Old May 5, 2018 | 04:03 PM
chaseestes's Avatar
I've been having the same problem as others in this forum where the Fit is dying the first time it is started. I read that this can be fixed with a possible valve adjustment. After one of these episodes where the car drops down below 1000 rpms and dies, i left ignition on. When I went to try and start it again this happened:
Is it a blown fuse or something? It wont turn over or anything, just this clicking. Has anyone seen this or Can anyone help?
Old May 5, 2018 | 05:25 PM
doctor J's Avatar
Your charging fuse on the positive terminal will be the first thing to check (the battery idiot light as well as check engine light should be on when turning key on) I see only oil pressure light which means the charging circuit and ECU are not energized; this may also cause battery to discharge (no cranking)
Old May 5, 2018 | 05:56 PM
chaseestes's Avatar
Doctor J,
Thank you, a ton for responding. I will give this a try and see if there are any results.
Old May 6, 2018 | 08:36 AM
fitchet's Avatar
Not sure this is the problem, but according to a quick google search, the green flashing key symbol is the vehicle not recognizing the immobilizer chip in your key.
Recommendations online vary from removing the key from a ring of keys and trying using it separately. To obviously replacing the battery in the fob.
Old May 6, 2018 | 04:59 PM
Fituna's Avatar
Dead battery?
Am I missing something?
Craig Cole
May 23, 2025 10:55 PM
douglasd5
May 23, 2025 10:49 PM
fitowner10
May 23, 2025 10:44 PM
budro
Jul 25, 2015 11:38 AM
robotfist
Feb 21, 2011 02:02 AM
