Transaxle Stress Cracks?
Old Sep 2, 2018 | 01:39 AM
der Mond's Avatar
Under the GD3 today I discovered a broken front mount and what would appear to be stress cracks in the transaxle housing. Anyone else get this?
Old Sep 2, 2018 | 10:56 AM
fujisawa's Avatar
I'll let another diagnose the stress cracks.. General opinion: if its not leaking, and its a major part of the engine, I'd let it go. But I might, uh, get a second opinion..
Is that an engine mount, usually one of three, or a torque damper (one of two, if you have them, I'm not familiar with the GD). My del sol has a broken torque mount and it was "fixed" with some rubber crammed in there ... But for an engine mount I recommend replacing it.
Old Sep 3, 2018 | 03:03 AM
der Mond's Avatar
I agree, I'm just going to drive it. The mount is the very front driver side attached to the transaxle, and an easy replacement. The new part from Majestic Honda should be here in a couple days. Thanks for the response.
Old Sep 18, 2018 | 02:46 PM
Fitty McFit's Avatar
I started a thread about this, then I saw this one. I did that same mount replacement, and I was wondering if yours looked like this when you took the nut and washer off. The shaft fits loosely inside the ring and doesn't contact it at all. I was trying to figure out if that's how it's supposed to fit or if something is wrong with mine. Thanks.
Old Sep 18, 2018 | 04:15 PM
der Mond's Avatar
I know, it surprised me also. I just chocked it up to Honda engineering knowing something I didn't, centering it the best I could, torqueing the nut on and forgetting about it. Logic suggests that it is more a fail-safe stop to prevent forward motion of the engine/transaxle unit in case the actual mounts fail, than a mount meant to be solid itself. But if anyone else knows for sure, that would be welcome...
Old Sep 18, 2018 | 09:22 PM
Thank you!
Old Sep 19, 2018 | 01:39 PM
carotman's Avatar
Those are casting marks, not actual stress cracks.
They are caused generally by fatigue in the mould used to cast the parts. Nothing to worry about.
https://www.researchgate.net/figure/...fig5_270226867
Old Sep 20, 2018 | 02:53 PM
der Mond's Avatar
Cracks
Hey, thanks!
Any idea why they take so long to show up?
Old Sep 21, 2018 | 10:22 AM
carotman's Avatar
I'm sure it's because the metal surface is a bit rougher in those spots and a bit more porous. You can't notice them until oil and dirt penetrates in the "crack". You can probably use an engine cleaner foam to make them virtually disappear.
allmotormark
Oct 10, 2014 01:16 PM
casandreas
Jan 11, 2013 08:49 AM
koolkevin1107
Oct 8, 2012 07:33 PM
CuTeBoi
May 4, 2011 06:57 PM
Wave
24
Apr 28, 2008 01:05 PM
