LCD radio display change notes (with pictures)
Old Dec 26, 2018 | 11:50 AM
doctor J's Avatar
Push on the tab before sliding the wire loop
Remove indicated screws (2 big, 6 medium) and pull the audio unit straight up
Route cables in front of the black wire loom!
Blue cable is for the heater, orange is for the mode selection and purple is for fresh/recirc big connector is for fan speeds, small for illumination and mode switch
Mode selector cam is pushing the microswitch in defrost position to tun on a/c
LCD screen on PCB board
Old Dec 26, 2018 | 01:44 PM
doctor J's Avatar
My old display
Right, top to bottom: mounting base, lighting prism, diffuser and the screen itself. It is made of 2 layers of glass with blue adhesive inside . When heated up it melts and migrates around creating voids which showing up as irregular white spots on the display. Very cheesy! The digital clocks on my 79 Supra and 87 Camry had outlasted the car!
SuperMacGuy
Fit I.C.E.
Aug 30, 2019 11:44 AM
jtraver
Feb 18, 2015 09:11 PM
hellgiver
Sep 10, 2014 09:26 AM
BamaBR549
Nov 12, 2007 10:56 PM
franceska
Apr 12, 2007 03:22 PM
