2007 Fit steering column cover
Old Jan 22, 2019 | 11:13 AM
g fit's Avatar
Is is safe to remove the upper and lower steering column covers without having the air bags exploding in my face?
They are just two plastic covers.
Old Jan 22, 2019 | 12:00 PM
nuocmumracing's Avatar
why wouldn't it be? undo the screws, and press in on the sides to remove the two pieces.
Old Jan 22, 2019 | 03:32 PM
g fit's Avatar
Thanks a lot.
Why wouldn't it be......if the airbags are somehow connected to them.
Old Jan 22, 2019 | 05:17 PM
doctor J's Avatar
I've done it; no airbag explosion (to swap ignition switch)
The upper cover is locked in a lower part by plastic tabs. Squeeze the upper part inwards, then pry it up with 1 inch wide spatula; sometimes removing screws at the bottom to detach cover assembly from the column makes entire assembly more flexible and easy to take apart.
Old Jan 22, 2019 | 09:42 PM
g fit's Avatar
Super! THANKS
tsand19151
Jul 15, 2016 04:01 PM
linowza
Feb 14, 2013 01:07 PM
gkitf16
Mar 12, 2012 11:07 PM
bluwater77
Mar 7, 2012 12:16 AM
storm
Jul 28, 2010 08:52 PM
