CEL Flashes on Cold Start
Old Jan 23, 2019 | 07:06 AM
ConureDelSol's Avatar
Hey all, I'm pretty inexperienced with car maintenance so feel free to put things in as simple terms as possible. I have a 2008 Fit Sport with roughly 140,000 miles on it. I initially took my Fit in to the mechanic due to having very noticeable multiple random misfires aggravated by turning on the AC.
​​​​​They ran engine codes and recommended I replace all the coils and spark plugs so I went along with it.
Car ran great. It was quiet, wasn't jerking, pick up was nice and I got a little gas mileage back. Couple of days later a CEL came on. Auto one ran it and it said Cylinder 2 misfire. Took it back to mechanic, they replaced the coil on that cylinder, CEL came back on a few days later.
Now, on a cold start, the car would rumble a bit, the light would flash a few seconds and then turn solid. Took it back and the mechanics were baffled. They replaced the coil again. At this point I started to wonder if they knew what they were doing since this is literally its third coil in less than a month.
No CEL for 3 days and it came back on this morning in 30 degree weather.
Is there any DIY things I can try before being obligated to go back to another mechanic. I'm about to just go to a Honda dealership but I really don't have money to throw at this problem and would like to avoid it if at all possible.
Old Apr 13, 2021 | 02:53 PM
MstaJohnsta's Avatar
Sorry I’m new to this site we’re you ever able to figure out what happen my 07 fit sport has this problem in cylinder 2
Old Apr 20, 2021 | 10:30 AM
doctor J's Avatar
What items did you change?
Assuming you used brand name, not counterfeit coil/plug
and there is no loose plug,
I would suggest checking ignition coil wire harness (rodents like to chew the wires) as well as checking the valve clearance "tight" exhaust valve can do that
Old Apr 24, 2021 | 08:50 AM
ikutoisahobo's Avatar
Everyone with a GD knows this problem. Like doctor j said, it's more than likely plugs and coil packs or valve lash adjustment or a combination of both.
Alex Smith
18
May 21, 2024 09:56 PM
danielomar91
Oct 11, 2022 04:17 PM
kschenk27
31
Jan 24, 2019 09:17 AM
BlueAngelFit
Mar 16, 2014 12:47 AM
Kholland
Nov 10, 2011 05:16 PM
