74mm piston on L15A7
Old May 7, 2019 | 10:17 AM
fitzai's Avatar
Hi,
Just to check with you guys that anyone of you using 74mm piston (+1mm from stock 73mm) with compression rate of 12.5?
Would you mind to share with me your setup and how is the engine base on the setup? is it reliable?
I am intending to do L15A7 with 74mm piston and 12.5 compression rate and also looking up to pair it up with cams. It would be helpful if you guys can provide me feedback if you have done it.
Appreciate and many thanks !
Cheers!
JJLudemann
Mar 8, 2018 02:43 PM
Ali.K
Nov 8, 2017 09:37 AM
nanoevil
Aug 3, 2012 10:47 AM
NoName
European Fit Forums & Clubs
Dec 26, 2011 09:15 AM
