Piggyback or Reflash for FBO?
Old Aug 8, 2020 | 10:05 PM
904_GE8's Avatar
Making this thread because I can't quite find the answers that I'm looking for. I currently have the Takeda CAI and an HKS Hi-Power axleback, and I plan on getting the HKS midpipe and Weapon R """header""" by the end of this year. I want to get it tuned once that's done, but I'm not sure how I should go about that. Should I get some sort of piggyback, or get my stock ECU flashed? Dyno tune, or e-tune? 2011 Sport 5MT with no Nav if that helps
Old Aug 9, 2020 | 11:23 AM
hotkey's Avatar
I prefer reflash. You'll probably need Ktuner (shameless plug: my unit will be for sale when I can unlock it from my ECU).
I previously used Unichip piggyback; got better results from flash tune. I've not tried e-tune; prefer dyno tune.
Old Aug 9, 2020 | 11:18 PM
904_GE8's Avatar
Thank you very much, I will go this route. Do I install the KTuner before or at the dyno?
Old Aug 14, 2020 | 10:59 AM
hotkey's Avatar
Ask your tuner.
Old Oct 4, 2020 | 10:50 AM
Jasonvicktory86's Avatar
Ktuner all the way. But one thing to note is there’s no upgraded maps on it. It’s just a speed density conversion where it uses the map sensor and not the maf sensor.
if you’re n/a you’re likely to see a max of 10 whp/wtq gains and that’s advancing the timing a crazy amount requiring 93 octane. Equalizing the air fuel ratio for an intake and exhaust will net you maybe ~5 on whp and wtq
You will gain midrange power around the vtec crossover which you can also define.
yuffers
Nov 20, 2014 02:09 AM
ThEvil0nE
Oct 5, 2011 02:56 PM
323sleeper
Nov 5, 2008 02:54 PM
xtreme
Jan 10, 2008 04:58 PM
China FIT
Oct 26, 2007 02:47 PM
