Got a question about the Zex Nitrous Kit install
Old Nov 21, 2009 | 09:00 PM
thefit09's Avatar
When I tapped my intake for the nitrous nozzle, the threads didn't come out right. The nozzle is threaded in where it doesn't fall out, it's just not "tight". What should I do? My friend suggested putting some JB weld around the nozzle to lock it in there. Thoughts?
Also, I'm not quite done with the install, it was getting dark and the mosqitoes were coming out. Haven't wired it yet, but I have almost everything else done. My check engine light has already come on though, I'm guessing it has something to do with the splitter connected to the fuel line? Any insight?
Thanks!
Old Nov 21, 2009 | 09:18 PM
Vanishing Point's Avatar
You could try Teflon tape on the threads.
Old Nov 21, 2009 | 09:22 PM
thefit09's Avatar
thought about it... also maybe loctite?
Old Nov 21, 2009 | 09:35 PM
Perrenoud Fit's Avatar
pix #30 and 31
You can use a brass bushing and redrill and tap the hole in the manifold, that would have a cleaner look about it. That way when you sell, it could be plugged when the kit is removed.
The JB Weld is a forever...... cobbjob #30 in the photo, hope this helps...........
Old Nov 21, 2009 | 09:41 PM
dewthedew's Avatar
yeah i would get it fitted properly and not use jb weld or somekind of silicone. do it right the first time.
Old Nov 21, 2009 | 11:35 PM
TurboManGT's Avatar
Perrenoud Fit has the best solution. Take your time when you are tapping the tube
Old Nov 22, 2009 | 02:28 AM
thefit09's Avatar
Thanks perrenoud, I'll try it tomorrow. Got your request, I'll let you know how everything goes.
Old Nov 22, 2009 | 06:16 PM
thefit09's Avatar
Which wire coming out of the fuse box is the 12V accessory power wire?
Old Nov 22, 2009 | 06:53 PM
thefit09's Avatar
Ummm... Ran the wire to the switch, but I need to power it... but I have no idea which wire is the 12V accessory power wire. AtticutFit?
Old Nov 22, 2009 | 09:59 PM
im the fit's Avatar
Baylorbro, what are your mods so far?
Old Nov 23, 2009 | 01:24 AM
thefit09's Avatar
Well this kit as soon as I figure out which wire is going to power the switch.
Then,
K&N CAI
Eibach Sportlines
Other small things like JDP mirror cap and license plate frame, JDM badge, red dot fit emblem, and vinyl foglight film. Does rear seat delete count? Haha, I'm pretty new to all of this, so I'm learning as I go.
My next planned mods are exhaust and enkei rpf1's.
By the way, this is supposed to be in the GE forum, just noticed I accidentally posted in the GD.
Old Nov 23, 2009 | 10:04 AM
NIGHTHAWKSI's Avatar
the red wire coming from the zex brain should be the wire that gets connected to the switch
Old Nov 23, 2009 | 02:08 PM
thefit09's Avatar
Right, there's that input to from the brain, but there's also another output that actually powers the switch. I have to use a spliter to piggyback power off of the accessory power wire to power this other input into the switch. Problem is, I had an aftermarket alarm installed and there are so many wires I have no idea which one to use.
Any more help would be appreciated, thanks!
Old Nov 23, 2009 | 07:26 PM
thefit09's Avatar
Everything's in place, got the bottle filled with 5 lbs at the only shop in town that does nitrous fills. Doing a test run tonight after work. Pics and impressions soon to come!
Old Nov 23, 2009 | 10:50 PM
Thumbs up after the test run.... who ya gunna spank 1st?
YEEHAA you go baylorbro let us know how long 5#'s last in the little bottle rock it! which are ya using 35 or 55 shot? wow that's 152/172 hp! Man I can't wait to hear from ya for a Fit even the GE8 that's fast!! Dude. If it's all good I'm really gonna B jones'n for some of the giggle gas for MzFiT.
I hope all went well and you have a Great story for all us kids
C- YA................................................ .... ..................................
Old Nov 24, 2009 | 07:24 AM
TurboManGT's Avatar
Can't wait for your impressions!!!
On a side note it seems that NOS kits have gotten more expensive since I've last looked. I remember shopping for them in early 2000s and I think they were around $300-400.
Old Nov 28, 2009 | 09:00 AM
rvall004's Avatar
I thinks this guy blew his enigne or someting cause he never came back to post first impressions...lol
Old Nov 28, 2009 | 10:16 AM
Sitt'n on the edge of our seats......
I'm keep'n up with baylorbro & he is wait'n for the plugs from ZEX and if it's goood for him i'll B soon behind with another ZEX install!!!!!!!!!............ The way I C it for 55 xtra hp 600.00 bucks in the Fit is the best $ spent.
Old Nov 28, 2009 | 03:47 PM
thefit09's Avatar
Yep, still waiting on the plugs from zex, have everything else hooked up.
Old Nov 28, 2009 | 08:33 PM
alvarospatchez's Avatar
Let me know how the project goes on. Are hooking up a purge or no? Also bottle warmer?
