2nd Gen GE8 Specific Fit Exterior Modifications & JDM Styling Sub-Forum Threads discussing exterior modifications and JDM styling for the 2nd Gen GE8 Honda Fit
Home made DRLs
Old Aug 12, 2014 | 05:26 PM
jjpineda's Avatar
Cool Home made DRLs
Hello everyone, check out my home made DRLs on my 2009 Fit in the album "My 2009 Fit".
Old Aug 12, 2014 | 07:16 PM
Yosemite's Avatar
What kind of LEDs are those? I bet they would look nice in the mugen lip as it has those little holes next to the foglight.
Old Aug 12, 2014 | 07:29 PM
jjpineda's Avatar
These are Eagle Eye 3 watt leds. They come in a case you bolt on to any surface and tighten up with the included nut. Bought them from ebay at about US$10 for 6 pack. You can find them individually and in other colors and wattage, even up to 9 watts each. Here's a link: eagle eye led | eBay
Where can I see the Mugen lip?
Old Aug 21, 2014 | 01:07 PM
Santiad's Avatar
diy?
Love the look...and want to copy it!....
where did you find the frame to hold the led's and bolt it on?
how do you wire it?
Hope to hear from you!
Old Aug 21, 2014 | 01:25 PM
MNfit's Avatar
why not just post the pictures in this thread?
Old Aug 21, 2014 | 02:30 PM
luismycorreo's Avatar
Nice look, I was thinking to do something like that and it will be more easy in my case due to the 2013 Fit Sport has a different Fog Light assembly.
I was thinking to make 2 or 3 holes on the sides of the Fog Assembly and put those eagles.
By the way I use one of those to illuminate my trunk and works fine...
Another option is the DRL using a SWITCHBACK LED in the turn lights housing
https://www.fitfreak.net/forums/2nd-...formation.html
Luis
Honda Fit Sport 2013 CndMkt - Blue
Old Aug 21, 2014 | 03:07 PM
ouch, that looks painful with the screw heads clearly showing.
can you use different screws or hide it or use rivets or something else?
Old Aug 22, 2014 | 07:06 PM
jjpineda's Avatar
Hi guys, for some reason (maybe my own ignorance) I could not post the pictures in the thread, sorry about that.
About the screws showing, it's not that easy to spot them unless you are really, really close as were some of my pics, so I really don't mind them.
About the frames, I built them myself out of handcrafting tin, it is malleable enough to easily form into any shape, and strong enough to hold the lights firmly.
About the wiring, since each LED uses 3 watts, it will be 18 watts in total so I decided to use a relay, the one used for aftermarket fog lights, in order to give the LEDs enough juice. To activate the relay I used the power from the DRL fuse, disabling the OEM DRLs and at the same time, powering the relay. The hardest part of the installation was passing the wire from the fuse box through the firewall to the engine bay.
Santiad, I'd gladly be more specific on the wiring if you need me to.
Yosemite
14
Oct 18, 2014 08:52 PM
xxgotfit?xx
14
Sep 24, 2008 06:30 PM
Crixtala
21
Aug 1, 2008 12:16 AM
trapat
Oct 23, 2007 01:31 AM
JDMchris.com
29
Dec 29, 2006 11:36 AM
