2nd Gen GE8 Specific Fit Exterior Modifications & JDM Styling Sub-Forum Threads discussing exterior modifications and JDM styling for the 2nd Gen GE8 Honda Fit
Replacing Entire Headlight Assembly
Old Feb 21, 2015 | 12:51 PM
ScaryDolphin's Avatar
Thumbs up Replacing Entire Headlight Assembly
Hey,
I have a base model manual transmission 2009 Honda fit. An icicle fell from our roof and smashed the plastic on the headlight assembly. I have purchased the headlight assembly, and I am wondering if its fairly easy to replace this myself. I searched the forums and saw instructions for replacing the bulb itself but not the entire assembly. Could somebody point me to some instructions for doing this?
Thanks in advance.
Old Feb 21, 2015 | 01:27 PM
xxryu139xx's Avatar
easy is a relative term. first time is kinda harrowing, but after you've done it once, it takes like less than 5 mins to remove the front bumper.
you'll need a #10 socket wrench and maybe a flathead and a phillips to take off some screws and pop off some clips.
You'll need to remove the front bumper. Raise up the front of the car. Open up your hood. Remove the 5-6 clips (depends on your model) on the radiator cover panel then take off the cover. There is one screw on each front wheel well. There is one screw at each corner at the bottom of your bumper and 4-6 clips under. Once you have those off start from the wheel well and pull the bumper off pulling up and towards you. The retaining clips will let go and you'll be able to remove the bumper.
The headlight is held on by 4 screws. There are two above and two below. 10 mm socket wrench should fit and remove all 4 screws. Pop on your new headlight.
Reinstall everything backwards.
You'll probably have to reaim the new headlight. Before you start any of this, make sure you point the car to the wall on level ground, and tape off the cutoff pattern against the wall with the headlights on. Once you replace the headlight, just adjust the beam pattern to where your tape is.
Have fun!
Old Feb 21, 2015 | 02:01 PM
Thanks xxryu139xx,
That doesn't sound too too bad. It seems like the worst part is removing the bumper and reaiming the light. Thanks for the response.
Old Feb 21, 2015 | 02:03 PM
xxryu139xx's Avatar
you're welcome!
Old Feb 21, 2015 | 05:05 PM
Thanks xxryu139xx,
I was able to replace the assembly with your tips despite a blizzard hitting me halfway through .
Old Feb 21, 2015 | 05:17 PM
xxryu139xx's Avatar
Originally Posted by ScaryDolphin
Thanks xxryu139xx,
impressive!
Destiny
Feb 28, 2019 10:35 AM
n9cv
Sep 23, 2014 11:40 PM
jazzman
May 12, 2014 12:39 PM
inxsole
Nov 10, 2009 12:46 PM
eglamkowski@angelfire.com
Sep 26, 2005 10:30 AM
