2nd Gen GE8 Specific Fit Exterior Modifications & JDM Styling Sub-Forum Threads discussing exterior modifications and JDM styling for the 2nd Gen GE8 Honda Fit
My JDM Fit RS Mugen Side Skirt
Old Aug 12, 2015 | 12:21 AM
BMW ALPINA's Avatar
This is the DIY:
Package arrived:
Unboxed, the color is dark blue, because Mugen had STOP Producing
this Fit RS Mugen Side Skirt and they do not have any in White color,
so...
Next stop, is Body Shop, Painted it Taffeta White
The Template provided from Mugen and Cut the template:
This is the Sticker to cover the holes from original Side Skirt Mounting:
Clean surface with Alcohol:
Mark the height of the side skirt using the template:
Cover the holes with the sticker:
Insert the front plastic plug:
Use the template for the rear fender wheel,
and install the mounting bracket:
Start peel off the backing tape from the Double Adhesive Tape,
but don't peel the entire length, just a little and then tape it
with another tape (so many tape hahaha)....
Install the side skirt, and start by tightening the rear screw,
while have another person holding the side skirt for you:
now the front fender wheel screw:
Use some plastic tools or small screw driver to make sure
the rubber trim do not get pinch:
Tightened the lower bracket (four or them on each side):
Peel off all the backing tape from the double tape,
and you are done:
Take pictures outside
Old Sep 25, 2015 | 04:36 PM
jdmj0's Avatar
Sorry to swarm you with questions BMW haha.
For these skirts, did you need to redrill holes into the body?
I know base fits need drilling if they install side skirts.
Old Sep 25, 2015 | 05:16 PM
BMW ALPINA's Avatar
Hi,
no redrill holes for Sports,
very easy to install
If you want to get one, you have to act fast,
last time I bought one they only have one in blue, gray and one more color,
it is already discontinued by Mugen...
joshowa
Oct 25, 2017 02:21 AM
SHG_Chiquita
Nov 10, 2013 08:45 AM
raspar
Aug 15, 2009 06:24 PM
90crxfreak
Apr 27, 2009 03:09 AM
