Lowe's Door Handle Screw Cap Mod
Old May 12, 2012 | 02:50 AM
hayden's Avatar
You can find these in the specialty parts drawers in the hardware department at home improvement stores. The ones I found were from Lowe's and were about 40 cents a pair in black.
You will need to drill out the back of the cap to a little larger than 3/16" with a drill bit, and then ream it out with a knife or something to make it a little bigger. Take a test screw out of the car beforehand to make sure each fits.
Be careful to not break the tabs when the thing is spinning in your hand. I broke several, and bought backups since I've used these before and thought it could be an issue. Use pliers to hold it, and drill against a box or something. Sounds easy, but these things are small and easy to mar.
Once done, tighten the screws into each cap in the door until you can get it to snap closed. I had to tighten them down til I almost couldn't turn the screw anymore before this would happen. Tight fit, but once they snap on, it's secure and shouldn't pop off. The hinge will catch it if they do. They look factory in color.
Makes our "cheap" interiors look a little more well thought out. Enjoy!
Old May 12, 2012 | 02:55 AM
Ekruceal's Avatar
That's awesome. I'll be doing this for sure.
Old May 12, 2012 | 02:43 PM
sfar785's Avatar
wow, something so simple yet makes it look so much better. I'll be doing this for sure.
Old May 12, 2012 | 02:49 PM
pig_pit's Avatar
Lol. Ive never realized that screw was there. Doesn't bother me that much for a trip to Lowes.
Old May 12, 2012 | 03:48 PM
Btrthnezr3's Avatar
Awesome! :-D
Old May 12, 2012 | 04:10 PM
teamkitty's Avatar
Thanks Hayden for doing this. I'll be doing it too. The devil is in the details...
Old May 12, 2012 | 04:35 PM
joey_fits's Avatar
Nice find! Thanks for sharing
Old May 12, 2012 | 08:31 PM
Ekruceal's Avatar
I was able to find them online, for those that don't want to make the trip to the store..
Shop The Hillman Group 2-Count Black Plastic Round-Head Screw Covers at Lowes.com
Old May 12, 2012 | 10:11 PM
Texas Coyote's Avatar
That is cool Hayden... It's the little things like this that I like to see.
Old May 12, 2012 | 10:16 PM
bmxman's Avatar
yeah what he said but good find!
Old Jun 1, 2012 | 08:28 AM
StuBeck's Avatar
For those who have an xacto knife, I found it was easier to just expand the hole with the knife than to drill it. If you go to Home Depot, the correct cap is the #6 one as well.
Old Jun 1, 2012 | 10:50 AM
FitStir's Avatar
Thumbs up
#6, cool. Next time I gotta pick up supplies, I'm going to make a quick stop to the screw aisle.
Great mod hayden, like I told you in the other thread. Really cleans/finished off the look.
Old Jun 1, 2012 | 11:44 AM
hayden's Avatar
Definitely is. I just had the drill out for some reason, and drilled against a box and it worked okay, but really anything to ream it out with would work better. Glad yall are enjoying this little finishing touch.
Old Jun 28, 2012 | 06:58 PM
Codger01's Avatar
I did this this afternoon. Anyone else who tries this, don't worry if the tab holding the cap on snaps, its easy to trim off the tab & the cover will still snap on. Just be carefull to catch it if you have to pop it off to get to the screw!
Old Jun 28, 2012 | 10:49 PM
swflej1's Avatar
I use some channel lock pliers, they worked well but codger is right if it snaps the caps still work.
Old Jun 30, 2012 | 05:00 PM
Gojulas's Avatar
This is what I did as well. It doesn't even take much scrapping to widen the holes ether.
The only thing I would warn about is that (at least at Home Depot) these are sold in three packs, but you have four doors to do! D'oh!
Old Jun 30, 2012 | 07:51 PM
Codger01's Avatar
Its always good to have spares!
Old Jul 1, 2012 | 04:47 AM
Black3sr's Avatar
While the screw is out take the panels off and replace the material. The caps will go well with the new black coverings.
Old Jul 4, 2012 | 05:27 PM
alanchan's Avatar
wow, that is super detailing
Old Jul 6, 2012 | 03:54 AM
Black3sr's Avatar
I did mine yesterday. It finishes off my black door material.
I just used drill bit in my hand to ream out the holes. Used a smaller bit followed by a larger one.
How many times have I had those screws out doing the material and winkers?
