Jonesing for a mirror with temp and compass...
Old Oct 2, 2012 | 02:06 PM
Grayfox's Avatar
I would like some advice from some persons who
have had such a critter installed.
There seem to be a couple of candidates:
Gentex GENK20A and GENK21A ( what is the difference?)
Also
CIPA 3640.
Any input would be appreciated...
The local Honda service manager did not think there should
be any problem with the wiring.
Thanks
Jerry
Old Oct 2, 2012 | 04:50 PM
spreadhead's Avatar
I have a CIBA in my Fit and a Gentex in my wife's Mazda 3. All things being equal I recommend the Gentex, but if the CIBA is cheaper, there is nothing wrong with it.
Old Oct 2, 2012 | 05:46 PM
grayfox- just a question, but do you have a smart phone? if so, i use an app on my droid that has both compass and weather along with convenient nav and other app buttons. much cheaper and convenient to have, if you already have a smartphone.
Old Oct 3, 2012 | 03:37 AM
Tk3's Avatar
Tk3
I'm also shopping for mirrors but I haven't decided which brand to get.
I found this information on a website that sells Gentex:
Please note that some of the 50-GENKxxA part numbers use the same mirror and indicate only a difference in the wire harness included with the mirror. For example the 50-GENK50A and 50-GENK51A both use the exact same mirror but include different harnesses. For these mirrors the "0" in the 50-GENKx0A part number indicates an aftermarket harness that uses heavier gauge color coded wire and includes in-line fuse holders, the "1" in the 50-GENKx1A part number indicates a harness manufactured by Gentex that uses smaller gauge black wire without the in-line fuse holders.
I assume this also applies to the Gentex GENK20A and GENK21A (the difference is probably wiring and fuses)
Also CIPA 3640
On another thread, I read a post from someone who really likes their CIPA. The only complaint I've read was that the instructions tell you to place the temperature sensor where it can get air (like in the grill) which can result in warm readings after idling for a while. I guess that could be a problem with any of these if you mount the temperature sensor where the engine could heat it up.
The main reason I hear people give for buying the CIPA over the Gentex is price. I'd like to know how they compare in regards to quality and accuracy (regardless of price).
-TK3
Aussie
Jul 11, 2019 10:03 AM
sissiromy
Jul 16, 2012 11:20 PM
Aeroplane
May 10, 2010 02:12 PM
einhan
Sep 26, 2006 10:36 AM
htewam
Apr 21, 2006 05:49 PM
