No power to USB Port
Old Jun 22, 2019 | 03:49 PM
tyler968's Avatar
So odd question, I have an 09 Fit, radio and cubby were previous scuffed super bad. So I saw as an opportunity to upgrade to 2013 Fit, Jet Black, and hey while I’m at it JDM hazard and USB.
My problem is I’m not getting power to the USB. What should I be looking at to troubleshoot?
Old Jun 22, 2019 | 06:46 PM
Action Jackson's Avatar
Use another working cable. That way, you'll know if it's the cable or port.
Old Jun 23, 2019 | 08:26 AM
eulogy's Avatar
id say make sure u plugged the usb cable back in to the back of the new radio. if i remember correctly the usb has its own little independent plug thats easy to miss.
but yes...check the cable first. usb cables can go bad from too much bending near the base and mostly from plugging/unplugging. the little pins wear out and get smashed down or break off.
Old Jun 24, 2019 | 02:45 PM
tyler968's Avatar
Found my problem, since I had 2009 Fit there was no fuse. Did some research, put in 20 amp fuse works great
Old Jul 12, 2019 | 02:04 PM
Fit2Bsquare$'s Avatar
Try with a known cable that works & check the fuses.
Nick Farrow
Oct 1, 2017 01:46 AM
k-man
Jan 5, 2015 12:04 AM
Bassguitarist1985
15
Sep 10, 2014 05:51 PM
awill14
Mar 28, 2014 08:29 AM
sofosal
Jan 15, 2010 11:19 AM
