Lights of Hazard Switch, A/C Switch & A/T Shift Center Console
Old Sep 15, 2019 | 09:10 PM
sepjovdc's Avatar
Question Lights of Hazard Switch, A/C Switch & A/T Shift Center Console
Hi guys! I just need some help with my Honda Fit 09 GE8 RS. The lights of the Hazard Switch, A/C Switch & A/T Shift Center Console Lights were working before but now they''re not lighting up. The Hazard Switch, A/C Switch and A/T Shift work perfectly except for the illuminating lights. Bulbs and fuse (#29 under dash fuse box) are all okay. Anyone had this issue before? Any idea on what's happening? Let me know if you guys need more details. Please advise. Thank you in advance!
Old Sep 15, 2019 | 10:03 PM
eulogy's Avatar
check each fuse one by one
Old Sep 15, 2019 | 11:02 PM
sepjovdc's Avatar
I mentioned fuse #29 because it's the fuse responsible for the illumination. Functionality of the Hazard Switch, A/C Switch & A/T Shift Center Console are fine and fuses are okay as well.
Old Oct 17, 2019 | 09:05 PM
JerrySFL's Avatar
Could just be bad bulbs, Could just be bad bulbs202 Fit base 90K, I just had to change the gear shifter bulb and both the back light lamp for defrost and AC switches, yellow and blue lamps work but switches dark at night. If the AC switch needs bulbs just buy a new switch it’s cheaper than the Honda bulbs.
m_x
Oct 21, 2014 12:03 PM
Codi
Sep 30, 2012 08:30 PM
Lyon[Nightroad]
May 2, 2010 02:12 PM
OhNineFIT
Sep 3, 2009 12:19 AM
Tomsfit
Nov 3, 2007 08:44 PM
