Lower control arm bolt size confusion
Old Nov 17, 2019 | 01:16 AM
gkitf16's Avatar
Question Lower control arm bolt size confusion
Going to be replacing the lower control arms on my '09 Fit base, and you are supposed to replace the arm mounting bolts when doing so. I referenced the following procedure guide, showing 4 bolts 14 x 1.5 mm
Front Lower Arm Removal/Installation :: Control Arms (includes balljoints) :: Suspension :: Chassis :: Honda Fit 2007-2019 Repair Manual :: Second generation (2007-2019) - HoFit.org
However, when looking them up here, there are several different bolts shown in the diagram
https://www.hondapartsnow.com/parts-...lower-arm.html
Item # 14, 2 req'd
https://www.hondafactoryparts.com/oe...QtYXV0b21hdGlj
Item # 15, 2 req'd
Finally, in the diagram a dotted box labeled B-48 there appear to be 2 different size bolts, one of which may be an item # 15 (?). There isn't a part listing for this B-48, so I'm stumped on this one. Who has done this job on a 09 Fit, and what are the actual sizes and their respective P/N's
Bolt sizes needed for arm replacement?
Old Nov 17, 2019 | 02:55 AM
teamkitty's Avatar
I swapped mine out a couple of years back and vaguely remember the same confusion around the bolts. Try checking a separate diagram for the front subframe and I think you'll find the part listings for the bolts in question.
-Rob
Old Nov 17, 2019 | 05:11 PM
julianachos's Avatar
My educated guess is this:
B-48 is the front subframe diagram - TK64B4800.
If you peep that diagram,your mystery bolts seem to be 5 (90162-TF0-000) and 7(90165-TF0-000)
https://www.hondapartsnow.com/parts-...sub-frame.html
Old Nov 17, 2019 | 06:08 PM
gkitf16's Avatar
Thanks Julian! Good eye on that, tough to tell between diagrams! So #4, 5 & 7 for the triangle subframe attach point. And #14 here for the LCA forward hinge point
Confusing to have to jump between 2 diagrams. Big problem if you screw up and order the wrong bolts with stuff laying disassembled. Why don't they just sell a kit pack for LCA replacement?
Old Nov 18, 2019 | 12:38 PM
evilchargerfan's Avatar
FWIW, I re used my bolts when I swapped my LCA's. it would be a smart idea to have a spare set on hand, in case one were to somehow have non-reusable bolts.
aaa12345
Mar 13, 2024 11:41 PM
Nvillegas
Jan 10, 2014 02:28 PM
bluesaint
Aug 14, 2013 11:11 PM
tanukifit
Jul 28, 2009 05:01 AM
F-IT!!!
Nov 18, 2007 12:38 PM
