6 speed manual transmission
Old Jul 3, 2020 | 06:16 PM
Eliseo Cortes's Avatar
Hi, have anyone used a 6speed manual transmission in a honda fit 2012 (L15A7)?
Or anyone up the gear ratio of 5th?
Old Jul 3, 2020 | 07:29 PM
Hootie's Avatar
The Japanese Spec Fit RS has a factory 6MT. I forget the gearing and exact model year range but look around 2011 to 2013 model years.
I personally wouldn't mind importing one of these RS 6 speed manuals myself but that will be further down the road.
Old Jul 3, 2020 | 10:45 PM
yeah, it could be epic... Im not bother to stay with my GE8 Transmission but if i could in some way, i wanna extend that 4th and 5th gear to be more comfortable when make my GE8 turbo.
Old Jul 3, 2020 | 11:59 PM
Red 05's Avatar
if it's anything like the CRZ transmission then 6th is the exact same ratio as 5th in the 5 speeds. The Fit was even sold with the CRZ running gear in the second gen. Hybrid electric assist would be kinda cool
They also sold the 1.3 with a 4wd option. With a decent motor that might be flippin quick
Old Jul 6, 2020 | 07:54 PM
Hootie's Avatar
It's not...Tthe CR-Z's 6MT transmission and gearing is slightly different (a pinch shorter in its top gear if I remember right and both cars are running the same tire size) than the 5MT Fit that we got in the states in the states. The RS 6 speed would be another story gearing wise.
The CR-Z's transmission is more on par with the R18 equipped 8th gen Civic. Heck the outer case, differential, some of the shift forks, and the counter shafts interchange between the two.
Old Aug 20, 2022 | 09:17 PM
2ndGen's Avatar
Has it ever been done here? RS tranny swap on USDM GE8?
Old Aug 21, 2022 | 12:16 PM
Hootie's Avatar
Doubtful BUT technically we do have the outer case and gearing already in the states. That's from the 6MT GK5 if I recall correctly while cross referencing parts a year or so ago.
The inner case/bell housing and mounts will need to be imported or sourced. Not sure what else currently.
Rodney Balines Lopez
Oct 27, 2020 01:41 PM
unclegibb
Feb 3, 2020 07:13 PM
CJfit15
Aug 19, 2015 03:45 PM
avosfit
26
Jan 9, 2014 09:36 AM
mommabear
Feb 9, 2010 03:57 PM
